ZC DOHC Tranny question
Old Sep 30, 2004 | 07:36 PM
digitals's Avatar
Default ZC DOHC Tranny question
Hey guys, whats up? well i have a 90' ef hatch w/ a d16z6 and i got a 1990 acura integra zc dohc tranny, the thing is, when i take off and try to shift to 2nd, it grinds bad, even tho i mash my foot all the way into the clutch. i still have the stock shift linkage from the dx, i also have a stage 2 clutch by grippower or something, im not too sure about the brand of the clutch cuz my brother got it off a friend. what do you guys think? do i have to get a new shift linkage to compensate for the dohc tranny? or is my clutch not installed properly? thx.
Old Oct 1, 2004 | 12:52 PM
digitals's Avatar
Default Re: ZC DOHC Tranny question (digitals)
well, guess nobody loves me......
Old Oct 1, 2004 | 01:26 PM
Sikocivic's Avatar
Shift linkage should be the same for ZC and DX. Sounds like you have a bad syncro in 2nd gear. Some guys have had good luck running GM sycromesh tranny fluid to stop the grinding. Might be worth a try.
Old Oct 1, 2004 | 05:03 PM
mar778c's Avatar
Community Builder
Community Influencer
just like Sikocivic said, 2nd gear syncro is shot. Just raplace the tranny. Get it from hmotorsonline, 150 + 75 for shipping
Old Oct 1, 2004 | 05:10 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitals &raquo;</TD></TR><TR><TD CLASS="quote">and i got a 1990 acura integra zc dohc tranny, </TD></TR></TABLE>
Has anyone noticed this? The 90 Teg was a B18A so he can't be using that tranny.
Old Oct 1, 2004 | 05:17 PM
DJ_SaNdOz's Avatar
Default Re: ZC DOHC Tranny question (dr_latino999)
he probably means the 89 teg, but I still dont see how that bolted up????
Old Oct 1, 2004 | 05:20 PM
Default Re: ZC DOHC Tranny question (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">he probably means the 89 teg, but I still dont see how that bolted up????</TD></TR></TABLE>
Exactly what I am saying!
Old Oct 1, 2004 | 11:24 PM
sloweredcivic's Avatar
some integras actually most i have sen have zc motors don't quote me on that i don't remeber there generations and years. you tapped and instaled the intermediate shaft i am hoping? the linkage is the same no difference. you prolly need a new synchro
Old Oct 2, 2004 | 10:16 AM
digitals's Avatar
Default Re: (sloweredcivic)
well, if it helps this tranny has lsd for some reason when i launch it both wheels spin i was so surprised i think it might be an older model tranny cuz it fit right in, well, if the shift linkage is the same well i should just change the tranny fluid see if helps, if not, bye bye lsd tranny , oh yeah, what tranny would be best for my setup guys? Thanks alot for posting btw.
Old Oct 2, 2004 | 10:23 AM
2point2's Avatar
d series - 2nd gear sucks
b series - 3rd gear sucks
Old Oct 2, 2004 | 10:59 AM
i wouldn't trash it the zc-lsd's are gettting hard to find and yeah you can buy another tranny for like 15o -300 bucks i would take that money and maybe a lil more an rebuild that replace second and have the others checked out because there is no garentee on other used tranny's
Old Oct 2, 2004 | 12:07 PM
drussell4801's Avatar
88-89 integras were d series dual cam motors. Very similar to the jdm dual cam zc. He definitely has a zc trans and not a b series trans, or else the **** wouldn't bolt up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic &raquo;</TD></TR><TR><TD CLASS="quote">some integras actually most i have sen have zc motors don't quote me on that i don't remeber there generations and years. </TD></TR></TABLE>
88-89 integras had d series dual cam motors. 90+ integras have b series motors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitals &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, whats up? well i have a 90' ef hatch w/ a d16z6 and i got a 1990 acura integra zc dohc tranny, the thing is, when i take off and try to shift to 2nd, it grinds bad, even tho i mash my foot all the way into the clutch. i still have the stock shift linkage from the dx, i also have a stage 2 clutch by grippower or something, im not too sure about the brand of the clutch cuz my brother got it off a friend. what do you guys think? do i have to get a new shift linkage to compensate for the dohc tranny? or is my clutch not installed properly? thx.</TD></TR></TABLE>
you most likely have a bad second gear synchro. There is a slight possiblity that your clutch cable is out of adjustment. Make sure that ****** is tight. If it still grinds, try to save the trans with GM syncromesh. It really does work wonders. Change that fluid out ASAP!
EDIT: at the very least, put honda MTF in it.
Old Oct 2, 2004 | 12:13 PM
davens's Avatar
I think he means the sohc zc that was in the 90-93 jdm tegs.
It's my understanding that this bolts into crxs, uses the smaller, standard L3 diff and has a 4.4 final drive.
Old Oct 2, 2004 | 12:20 PM
AbusedSkin EF9's Avatar
If you dont have any other grinds in other gears, then its just your 2nd gear syncro. its a pain in the a$$. good luck bro.
Old Oct 3, 2004 | 08:24 AM
digitals's Avatar
Default Re: ZC DOHC Tranny question (AbusedSkin EF9)
i just found out it also grinds 3rd gear as well, it doesnt grind 4th gear or 5th, i was hauling *** on the freeway and i went all the way up to 95 on 3rd, then shifted to 4th perfectly at 7200 rpm...thanxs guys for posting ill try that gm syncromesh stuff, does anybody know where i can get it? maybe a dealer?
JDMefHATCH7
12
Sep 7, 2010 12:39 PM
hondacivic90zc
16
Jul 19, 2007 11:13 PM
ZCRexSnglecamV
12
Jan 5, 2007 12:47 PM
91 ZC hatchback
Jan 2, 2006 10:01 AM
SC-MK1
May 27, 2005 06:23 PM
