what would cause a 3k rpm ?
Old Sep 30, 2004 | 06:48 PM
showtymers619's Avatar
* B A N N E D *
Default what would cause a 3k rpm ?
so far ive checked coolant.. i let it run without the cap on to release as much airpockets
the IACV has recently been changed from the dealer
i reseted the ecu
swaped map sensor still the same .. any more clues?
Old Sep 30, 2004 | 06:50 PM
Luserkid's Avatar
Default Re: what would cause a 3k rpm ? (ShowTymers619)
huh? What exactly is wrong? What car/motor? Thats to vague for anything.
Old Sep 30, 2004 | 06:52 PM
ej1 pilot's Avatar
Default Re: what would cause a 3k rpm ? (Luserkid)
limp mode
Old Sep 30, 2004 | 06:53 PM
* B A N N E D *
Default Re: what would cause a 3k rpm ? (Art In Motion)
its a 91 LS .. its not in limp mode cuz i resetted the ecu already.. even th it didnt have a check engine light on
i heard the a bad fitv could have the sam esymtoms.. but as high as 3k rpm? idle
Old Sep 30, 2004 | 06:55 PM
explosive's Avatar
What exactly is happening at 3k? You haven't really been too descriptive.
Old Sep 30, 2004 | 06:56 PM
ej1 pilot's Avatar
Default Re: (explosive)
i think he means the revlimit hits at 3k...right?
* B A N N E D *
i thikn i explained
3k rpm idle LOL
ej1 pilot's Avatar
Default Re: (ShowTymers619)
ohhhh, lol
Old Sep 30, 2004 | 06:57 PM
Luserkid's Avatar
Im thinking a 3k idle?
If so look at your throttle cable and make sure its not stuck, also look at the throttle body and make sure nothing is in it.
* B A N N E D *
Default Re: (Luserkid)
yes i checked the cable.. i removed the IACV and looked if the screen is dirty .. its clean..
Old Sep 30, 2004 | 07:02 PM
hondainspired's Avatar
HUGE Vac. leak somewhere??!?! (but that would prob. bounce up and down dramaticly if that was the case)
Old Sep 30, 2004 | 07:04 PM
* B A N N E D *
Default Re: (hondainspired)
ya a vacuum leak woudl bounce... but this is steady starting at 3k rpm and rises little by little.. so i dont even want to warm it up fully not knowing how high it will idle lOL
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
crxnonvtec
22
Sep 3, 2009 02:52 PM
dc2_916
Mar 10, 2008 06:20 PM
CRX_Control
Dec 30, 2004 11:03 AM
1.8EG-T
10
Mar 26, 2003 10:04 AM
