Prelude Clutch Padal help!!
I have 93 prelude vtec, the problem is the clutch padal just falls on to the floor when i step on it. I try bleeding it but there weren't any pressure yet. Does anyone know why and how to repair it>>?
Ive had the same problem dude...
Theres a few things you need to check.
First of all, check your resiviour, does it have fluid?
yes? is it still full? if yes, check plunger behind the pedal.
If NO or there is some fluid missing, you need to find out where it is leaking at.
Check the Master cylindar and the slave cylindar. Look for ANY sort of liquid around it. On the master cyl, check behind the pedal where the plunger goes into the master cyl. If its just grease its fine, but if the grease seems a little more like oil or hydrolic fluid then the Master Cyl is probably the problem.
Check the slave cyl. Its located on the forward side of your transmission. It has a hose and a bleeder valve that looks exactly like the ones on the brakes. Inspect the rubber sleeve by sliding it to one side. Your looking for any sort of fluid there too. If you find any, then you have located what needs to be replaced.
If youve gone and checked all 3 of these so far and see nothing wrong, then I dunno what to tell you man. Ive had my clutch randomly hit the floor, and when I pull it back up its just like new again. Ive replaced everything clutch related and it still falls about once every 4 months. I hate ghost gripes.
Lemme know how it goes.
Yeah thanks for your advise dc_honda. But i remember searching for leaks, but it might be like u say - behind the padal. All i see is the O rubber, it has gease but not sure it's fluid. I will try all three places..hopefully it sovles the problem.
ej1-usdm
Dec 5, 2007 04:03 AM
JLange
Mar 30, 2003 04:31 PM
