injector sizing and boost question for my gsr turbo
Old Sep 30, 2004 | 02:58 PM
b18c1wes's Avatar
Default injector sizing and boost question for my gsr turbo
i have a turbo gsr motor in a civic. its a t3/t4 turbo running 5.5psi of boost. i need injectors because now im running stock injectors on a fmu and i figure with the injectors and fmu i can turn the wick up a little.. id like to set a target of 7-9psi of boost if thats not to much... what size injector should i use ,i was thinking 360cc around there and also what boost should i be running on a stock jdm gsr motor.. compression is 10.5or 10.6 to 1 my mods are listed below.... thanks
Old Oct 1, 2004 | 03:21 PM
b18c1wes's Avatar
Default Re: injector sizing and boost question for my gsr turbo (b18c1wes)
Old Oct 1, 2004 | 04:16 PM
donkiman's Avatar
i have a very similar setup. you might wanna invest in an actual ems if your considering turning the boost up. I run 9psi with hondata with a conservative tune and see 290whp. as far as injectors go u can really go as big as you want. the 360's, 440's, and 550's all cost relatively the same. I went with 550's for room to expand later. or the cheaper way would be to get some 450 dsm's.
Old Oct 2, 2004 | 05:45 AM
b18c1wes's Avatar
Default Re: injector sizing and boost question for my gsr turbo (donkiman)
hows this setup walbro 255 pump (already in the car) dsm injectors,vafc,and an adjustable fuel regulator... can you use the adjustable fuel regulator with the vafc... is that a good setup.. i need to know need to start buying very soon ive gone to long on stock injectors
Mephistopheles
Feb 15, 2021 05:17 PM
jamesfawcett
Apr 13, 2010 01:33 AM
95dc2teg
Jul 16, 2006 12:58 PM
4dr*sleeper
Aug 16, 2005 12:33 AM
honkey2fly
Apr 22, 2004 11:50 AM
