crx dx what to do
Old Sep 30, 2004 | 01:22 PM
crx90rcr's Avatar
Default crx dx what to do
i saved about 4200 $$ k , i dont kno what to do , so many ways to do it, turbo b16 dohc vtec ,non turbo b18 vtec , do a mini me swap deal just want to c what u smart people think is the better way to go to get a 13 sec car
Old Sep 30, 2004 | 02:14 PM
prettyQuik's Avatar
Default Re: crx dx what to do (crx90rcr)
it depends...is this your race car, or daily driver. to you like interior, or do you want to gut. a little more info on how you would like the car to drive and we can help you out
Old Sep 30, 2004 | 02:45 PM
crx90rcr's Avatar
Default Re: crx dx what to do (rexboyb18)
id like this car to be a daly driver that i still could run at the strip and have fun in
i dont really mind how the interior looks as long as it has both seats
and some subs and stuff like that so i dont want to strip it down for daily driving but i will remove my subs and my seat and all the crap in the back 4 when i am playen around i want this car to last like 3 years till i get out of collage and i have enough money 4 a nice new 4wd car so what do u think would b best i wouldnt mind putting in up to 10 000 but thats over the 3 years not now what should i do now
Old Sep 30, 2004 | 02:50 PM
Joebroni's Avatar
Save up a little more and build up a CR-VTEC.
Old Sep 30, 2004 | 03:28 PM
prettyQuik's Avatar
Default Re: (Joebroni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joebroni &raquo;</TD></TR><TR><TD CLASS="quote">Save up a little more and build up a CR-VTEC.</TD></TR></TABLE>
good set up if you want all motor, lots of places you can build power. a little expensive if you wanna turbo one tho. ls blocks are cheap, have low compression and long gears are good for turbo set ups. you should run 13s with a ls turbo no doubt
Old Sep 30, 2004 | 03:50 PM
mr_valentino20032000's Avatar
Default Re: (rexboyb18)
you know with the battle between the two "H to B series" you could put in a H22 with a B series tranny and run like 12-13 seconds no problem with no boost.
Old Sep 30, 2004 | 03:52 PM
gsrdragster's Avatar
Here's what you do! buy a b16 motor ($600-$1000) get a 94 LS bottom end with trany!($400) buy a hasport Eb2 change over mount kit($500) Hydrolick Clutch!($400) Take the head off the b16 and use the rest of the motor parts to complete the motor .purchase 12:1 compression forged flat tops racing pistons($700 complete set including rings or surf the web and get it for($400) purchase a TODA spec B cam!($1100-or $1500 if you want the timing belt with it!)
!!THIS IS A SET UP WHERE RUNNING 13s IS THE LEAST OF YOUR WORRIES!!!
your total cost 600+400+500+400+700+1100=$3700
oh yeah! machean work for the block maybe $500!
p.s if you want to get tricky you bore the block to a 2.0 liter and run the flat tops at 84millimeter!!!
Old Oct 1, 2004 | 03:58 AM
crx90rcr's Avatar
Default Re: crx dx what to do (gsrdragster)
yea so just get a ls vtec and it should b good and a turbo and im sure stock rims wont cut it too small tires rite and what size rims would look good but still have traction at the track
littletruck
Oct 21, 2005 01:46 PM
EFin' Kyle
Aug 5, 2004 02:13 PM
EL Vap133
61
Jul 27, 2004 12:41 PM
HUBB
34
Apr 13, 2003 07:27 PM
