ported or sealed?
hi would it be better to have 2 10" alpine type E's in a sealed or ported box, with a alpine mrp-m200 amp. like which one would be louder?
sorry for the noob question
Modified by Hoang at 10:28 PM 9/30/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoang »</TD></TR><TR><TD CLASS="quote">hi would it be better to have 2 10" alpine type E's in a sealed or ported box, with a alpine mrp-m200 amp. like which one would be louder?
Modified by Hoang at 10:28 PM 9/30/2004</TD></TR></TABLE>
If you build the box with the correct air size and port sizing, then the ported box would have a slightly higher dB output, but it would loose out in the low end bass (really deep). The sealed box will have a better range into the deep bass, but won't be quite as loud.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eric’s R »</TD></TR><TR><TD CLASS="quote">..if the ported doesn't sound better than the sealed one, it's not properly tuned.</TD></TR></TABLE> Dito that
A properly tuned box,[port] will have a lower F3 point, will be louder, or use less watts to get to the same SPL, that said, a sealed box is easy to make, 10% up or down in air volume will not hurt, but getting a ported box tuned right can be a pain, I do mine in the car, have found that lenth of port can vary +/- an inch or so from my box programs to when I put the box in the car,[loading I think]
94
94
I personally perfer sealed because i feel it is punchier and cleaner, but possibly i didnt have it tuned right? I dunno. I think ported is overall louder though.
if u just want it to thump get bandpass. bandass isnt very accuracte tho. sealed is the best all around. ported needs more watts to go deep imo. i have 2 12's kicker in a sealed and its super clear. u might need bandpass cuz type E's might not soudn good in sealed
i went from sealed to ported when i had my JL AUDIO 10W7.
i probably will never do sealed again.
ported was better overall with the same amp (500/1)
and NO bass boost with ported versus sealed.
sealed box was made to jl's specs.
ported box to vteg's specs
that could have something to do with it
I feel I should comment on this.
There is good reason to use a ported enclosure in home theater applications. It will provide great output, and a shallower rolloff on the low end (before tuning frequency) to properly match the average home theater's room-gain (transfer function).
For a car, though, this type of flatter anechoic frequency response will generate an audible "hump" in the graph (Decibel vs. Frequency graph, AKA Frequency response graph). Why? The car is a smaller environment: a smaller room will generally boost lower frequencies a great deal... an estimation, for compact cars, is about 12db/octave with +3db point starting at 50-60hz. This can translate into 20+ db of boost below 30hz. Some people like this "one-note" accentuation, but for SQ purposes, a bass-EQ is necessary.
Fortunately for us, sealed enclosures exhibit a low-end rolloff nearly opposite to the cabin-gain seen in vehicles ---> Sealed enclosures will generally give us a flatter curve.
Additional benefits of going sealed:
LOWER bass (Ported enclosures won't effectively play too far below their tuning frequency; Using some headphones, I can hear below 20hz given enough output...and we all can FEEL it - it's rare in music, but it's there)
No Subsonic Filter required - Below tuning frequency a subsonic filter is needed to protect the subwoofer...the cone looses control otherwise and may over-excurse.
Easier/Smaller: Sealed enclosure are less sensitive to T/S parameter misalignment (Basically that an enclosure's volume needn't be EXACT); sealed enclosures require less space. There's much less work in tuning a sealed bass system; no concern for the phase-shift / group delay graphs to ensure that you're not doing something stupid (below about 25ms isn't too audible)...no concern for port length and vent-air velocity...lower build cost... generally less EQ'ing required (or no EQ at all).
I'm going to suggest that one go for ported only if they need the output, and/or if they have a capable bass EQ (1/3 octave from 25-80 or so), if they enjoy the accentuated sound, if they have the extra space...
Ported Enclosures CAN retain the SQ of sealed, just depends on application and effort.
Later
Later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PFTKev »</TD></TR><TR><TD CLASS="quote">Ever consider a good bandpass box?</TD></TR></TABLE>
I'd say check their website and go with their specs. They know what type of boxes their subs go with, and they give you dimensions and a blue print of how the box should be.
Me, personally, I'd go with a rectangle port with it's own path and polyfill on the inner walls.
im_the_teacher
Audio / Security / Video
Dec 15, 2003 12:16 PM
