Cylinder Head Assembly Question?
Old Sep 30, 2004 | 12:52 PM
Xion's Avatar
Default Cylinder Head Assembly Question?
I got another quick question for you guys?
When reassembling a B16a head, does it matter where the cam holders go, since they both are identical. I marked them when I pulled it apart but I guess the marker I used was crap b/c I can't see the marks anymore. I know where all the cam bearing caps go and I know those have to go back in the same place.
The two cam holders look identical though and I just wanted to know if it matters where they go. I don't see any markings on them and I looked them up and they are the same part number.
Thanks for the help once again H-T.
(btw I did search )
Old Sep 30, 2004 | 03:33 PM
Xion's Avatar
Default Re: Cylinder Head Assembly Question? (Xion)
Old Oct 3, 2004 | 02:48 AM
Xion's Avatar
No ideas guys?
Old Oct 3, 2004 | 04:10 AM
b00sted93Hatch's Avatar
Default Re: (Xion)
Yes it does matter. 3 center cam caps have number stamped on each one. Starting from left to right, it should read 4,3,2. Make sure the arrows point towards the crank pulley.
Old Oct 3, 2004 | 04:20 AM
Xion's Avatar
Default Re: (allMotor93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allMotor93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Yes it does matter. 3 center cam caps have number stamped on each one. Starting from left to right, it should read 4,3,2. Make sure the arrows point towards the crank pulley. </TD></TR></TABLE>
Yeah I know that. I'm talking about the cam holders on a DOHC. They look like 2 long strips that bolt down over the cam caps. It's the last pieces you install when assembling the head.
Old Oct 3, 2004 | 05:49 AM
slambedcivic's Avatar
Default Re: (Xion)
theres only one way they can go in.... the 10mm bolts need to be on the crank pulley side... with the valve cover studs facing into each other.. just remember.....20ft/lbs on the 12mm bolts and 7.2ft/lbs on the 10 mm bolts.
Old Oct 3, 2004 | 08:18 AM
Xion's Avatar
Default Re: (slambedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic &raquo;</TD></TR><TR><TD CLASS="quote">theres only one way they can go in.... the 10mm bolts need to be on the crank pulley side... with the valve cover studs facing into each other.. just remember.....20ft/lbs on the 12mm bolts and 7.2ft/lbs on the 10 mm bolts.</TD></TR></TABLE>
Thanks man.
Old Oct 3, 2004 | 02:03 PM
Default Re: (Xion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xion &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks man. </TD></TR></TABLE>
not a problem
boostlsveg
Jan 29, 2014 09:27 AM
supaslowdx
Sep 24, 2009 08:57 AM
gutted-dx
Dec 23, 2008 07:26 PM
tvrsir
17
Jul 9, 2004 07:30 AM
