Screen on turbos good or bad?
I see lots of set ups of turbos my buddy got his done at a shop and when he got his car back it only had a screen over it instead of a filter what are the pros and con's if any of using a screen over a filter like the greddy kit comes with.
Well a screen is alot better than nothing.. It keep rocks and bugs from flying into the turbo..
If you can run a filter then great but other than that just run a screen..
I have the filter on my gsr integra now with the greddy kit i was just wondering because i see so many people with ou them that may be they benfit from it in some type of performace way? I was told by this old guy that if you dont have filters on the end of the turbo that it will rapidly lower the life spand of the turbo???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">i think i picked some up also from just running the screen
Plus you can hear the turbo spooling alot better.. Call me crazy but I just love the sound of a turbo spooling..
</TD></TR></TABLE>Plus you can hear the turbo spooling alot better.. Call me crazy but I just love the sound of a turbo spooling..
Well I have a ractive foam style filter, and with it off it only gained 2hp. So I don't think that it's really worth the 2hp to run it w/o a filter.
I can see how he says it makes the turbo last a little longer by leaving a filter on to protect the blades but performance wise i dunno I think its pretty much the same
I guess if your driving your car everyday that its important to try to put a filter on it so no dirt and stuff gets into your engine..
My turbo car is for track only so I could care less about the dirt..
On my last integ I ran both and it seemed like the car felt better with the intake attached. That's just based on the butt dyno though. Air intake temperatures could have something to do with it since the pickup point is in a cooler spot with the intake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol »</TD></TR><TR><TD CLASS="quote">only reason I use a screen is because I can't fit a filter on, still trying to find one small enough though...</TD></TR></TABLE>
Same
Same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol »</TD></TR><TR><TD CLASS="quote">only reason I use a screen is because I can't fit a filter on, still trying to find one small enough though...</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr »</TD></TR><TR><TD CLASS="quote">
Same</TD></TR></TABLE>
me too. or i need to find some piping that i can fab up to place a bigger filter somewhere else.
I remember an old post where someone tested the screen method and it actually flowed worse and created more turbulance than a filter. Its all about surface area, filters have a lot verses a screen with only a few square inches.
same here, im going to try to have a local muffler shop that carries 3inch mendrel bends fab up a cold air intake for the turbo that locates the filter where the windshield washer resorvoir used to be. I was also thinking of trying to fab up an air duct using the opening on my mugen front lip to shoot air right into the filter of the turbo. Ill take some pics whenever im finished.
I'd defenitely use a filter if you can. As other have stated, fabed a pipe up so that the filter can get some cold air if possible, it can't hurt. I use a filter too as my car is a daily driver.
slowteg550
Jul 24, 2006 01:57 PM
