where is the fuel relay located on a ef ?
Old Sep 30, 2004 | 10:18 AM
ian.'s Avatar
Default where is the fuel relay located on a ef ?
exactly the topic asks
Old Sep 30, 2004 | 10:22 AM
hatchinprogress's Avatar
Default Re: where is the fuel relay located on a ef ? (IC33)
bump cuz id like to know also
Old Sep 30, 2004 | 10:29 AM
CRXBart's Avatar
It's the main relay, it is under the drivers side of the dash, up underneeth, off to the right. Do a search under main relay and you should find what u need. It is a common problem on our cars.
Old Sep 30, 2004 | 10:31 AM
ian.'s Avatar
Default Re: where is the fuel relay located on a ef ? (CRXBart)
thanks man
Old Sep 30, 2004 | 10:45 AM
crx_88_si's Avatar
right above the hood release
Old Sep 30, 2004 | 10:46 AM
CRXBart's Avatar
no problem
Old Sep 30, 2004 | 10:56 AM
Creepshow S60's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">It's the main relay, it is under the drivers side of the dash, up underneeth, off to the right. </TD></TR></TABLE>
...it's actually off to the left. to access the main relay, you can look under the dash and take off the fuse panel thingy (yes, that's the technical term...lol).
you will see a little black box type thing after poking around there for a minute. it will say "relay:main" or something along those lines.
W0oT's Avatar
Banned
Default Re: (crx_88_si)
if ur just trying to purge off res.. pressure just unplug the plug under seat... otherwise yup barts right and so is crx 88 si. it's mounted to the door jam w/ a 10 mm bolt. 1 plug underneith
Old Sep 30, 2004 | 11:14 AM
ian.'s Avatar
Default Re: (Majin Vegita)
thanks guys nah iam trying to replace it
Old Sep 30, 2004 | 03:47 PM
mar778c's Avatar
Community Builder
Community Influencer
Yes
EKHWhat
Mar 17, 2007 11:41 AM
sidewayz32
14
Nov 12, 2005 06:40 AM
hatchback_al
Nov 5, 2004 04:53 PM
fred92htch
Aug 22, 2003 05:48 AM
el_Presidente
May 11, 2003 01:36 PM
