flat tire on a dropped suspension ... ? plz help .
Old Sep 30, 2004 | 09:16 AM
killaj12's Avatar
Default flat tire on a dropped suspension ... ? plz help .
i just bought a 00 si which came with eibach sportlines ..
and my friend told me that if i got a flat tire, i wouldnt be able to use the stock car jack to raise the car ..
is this true ? and if it is, is there an after market one that will work ?
or will i have to get it towed all the time .. ?
Old Sep 30, 2004 | 09:18 AM
Team 4R's Avatar
Default Re: flat tire on a dropped suspension ... ? plz help . (killaj12)
you probably aren't low enough to have a problem with car jacks.... but, if you are, just drive the car onto a piece of wood and then jack it up.
Old Sep 30, 2004 | 09:19 AM
hype r 555's Avatar
jack your car up by the tow loop in the back under the trunk and then put a jack under it .... it's that easy ... i do it all the time !
Old Sep 30, 2004 | 09:27 AM
99SlammedCivic's Avatar
Snipper Snapper
the stock honda jack will work just fine !
Old Sep 30, 2004 | 09:28 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: flat tire on a dropped suspension ... ? plz help . (lsed-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsed-eg &raquo;</TD></TR><TR><TD CLASS="quote">jack your car up by the tow loop in the back under the trunk and then put a jack under it .... it's that easy ... i do it all the time ! </TD></TR></TABLE>
That would probably only work if the flat is in the rear.
I don't think your low enough to not be able to us the stock jack. You might be to low to use a regular hydrolic jack and would need either a low profile jack or drive onto a piece of wood and then jack it up. When you use a hydrolic jack you can then lift from the front lifting point and from the rear tow hook.
Old Sep 30, 2004 | 09:31 AM
hayabusa160's Avatar
Default Re: flat tire on a dropped suspension ... ? plz help . (TouringAccord)
should have no problems with the honda jack.
but the other jacks you will like those pump jacks you get from craftsman and such.
also the stock donut wont work on a slammed car lol try to put it on and see what happens hahah
Old Sep 30, 2004 | 09:33 AM
ej1 pilot's Avatar
Default Re: flat tire on a dropped suspension ... ? plz help . (hayabusa160)
my car is slammed, i just lift up on the wheelwell and get someone to place the jack under then drop
Old Sep 30, 2004 | 09:35 AM
crashN2u's Avatar
Default Re: flat tire on a dropped suspension ... ? plz help . (Art In Motion)
Carry 2x4's everywhere you go.
Old Jun 29, 2005 | 06:51 PM
BLUE EH3's Avatar
Help we my pennies
a stock jaxk workS
crx12
May 1, 2008 10:24 PM
Nameless Warrior
11
Nov 3, 2006 03:25 PM
cbseven
May 25, 2006 11:06 AM
Stinkycheezmonky
Apr 7, 2004 07:38 PM
Darren94ls
Jul 13, 2001 03:05 AM
