Help... KYB shocks adjustment
I have a 1992 integra gs with neuspeed sport springs 2" drop on KYB adjustable shocks. I need to adjust the shocks to a more comfortable ride all around but I need do know which setting to use and how I would know which setting its at as I adjust.
Thanks!
Modified by luv2cruz at 5:00 PM 9/30/2004
Thanks!
adjust your springs? o_O If you mean shocks, there are numbers on the shocks and you adjust it with a screwdriver or a ****, IIRC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garados »</TD></TR><TR><TD CLASS="quote">adjust your springs? o_O If you mean shocks, there are numbers on the shocks and you adjust it with a screwdriver or a ****, IIRC. </TD></TR></TABLE>
Yeah, just use that little yellow screwdriver they give you and adjust it. There are number on the top (1-4) with 1 being the softest and 4 being the stiffest. Try playing around with the settings and see which is the most comfortable for your ride.
Edit: B18B beat me to it.
o.k but when looking at the shock when I adjust how do I know which setting it is at? If I turn the setting with the screwdriver should lets say I want setting 3 is it suppose to lock so I know that is that setting.
theres numbers to know where u set it,push down and turn with the screwdriver,when u have it at your desired setting,and u just let off and the adjustment screw pops up in place where u left it..
user 98292739
Feb 2, 2005 07:48 PM
Cryptopsy
41
Dec 19, 2002 01:24 PM
