ITR Steering Rack on a EK
Old Sep 30, 2004 | 05:01 AM
project.mu's Avatar
Default ITR Steering Rack on a EK
what is needed for the swap of the whole cross member into the EK, do i need the steering pinion changed too..
Old Sep 30, 2004 | 05:31 AM
monicle's Avatar
Default Re: ITR Steering Rack on a EK (n1taboo)
its not going to bolt up. they have different mounting locations.
Old Sep 30, 2004 | 09:05 AM
project.mu's Avatar
Default Re: ITR Steering Rack on a EK (monicle)
are u sure cuz i just bolted it up, its from a 2001 Type-R, and it fits perfect, and insted of 2 turns from steering its now 1.5, so its close ratio....its nice, + sway bar, hmm, hmmm good...
Old Oct 1, 2004 | 07:14 AM
monicle's Avatar
from an integra type r? Id like some pics if youve got them.
Old Oct 1, 2004 | 08:08 AM
EK22snatch
Guest
Posts: n/a
even if it does fit, its a pretty big waste of time and money unless you got the hypeR front clip and are swapping the engine in too.
Old Oct 1, 2004 | 08:52 AM
Ajax's Avatar
Default Re: ITR Steering Rack on a EK (EK22snatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK22snatch &raquo;</TD></TR><TR><TD CLASS="quote">even if it does fit, its a pretty big waste of time and money unless you got the hypeR front clip and are swapping the engine in too.</TD></TR></TABLE>
Bah, can you tell me why this is? I believe the ITR has a tighter steering rack... which equals quicker turning. Now why is this a waste?
Old Oct 1, 2004 | 09:20 AM
TallAssFilipino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1taboo &raquo;</TD></TR><TR><TD CLASS="quote">are u sure cuz i just bolted it up, its from a 2001 Type-R, and it fits perfect, and insted of 2 turns from steering its now 1.5, so its close ratio....its nice, + sway bar, hmm, hmmm good... </TD></TR></TABLE>
Just four hours before, you were just asking what you needed to bolt it up? Also, as far as the steering wheel only turning 1.5 turns instead of 2, I think you mean it short ratio. It can't be close ratio. Close ratio to what? There's no other gear it switches to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ajax &raquo;</TD></TR><TR><TD CLASS="quote">
Bah, can you tell me why this is? I believe the ITR has a tighter steering rack... which equals quicker turning. Now why is this a waste?</TD></TR></TABLE>
A couple years ago I've found they sold something like steering rods (I don't know the correct name) in a set of two. They were meant for Civics. It allowed them to have a more tighter and more precise steering as equal to the Integ's if not better. The price and labor on those were much less than replacing the entire steering rack and pinion.
Any Integ's steering rack is good for straight-away's, but for anything like Auto-X, I'd keep the Civic's steering rack for its better turning radius.
HugoR
Sep 7, 2022 02:54 PM
project 2two9
Nov 17, 2006 08:06 PM
project 2two9
Nov 17, 2006 04:18 AM
ff terror
May 26, 2005 07:47 AM
