Energy Suspension Motor Mount Inserts for jdm ee8/9
Old Sep 29, 2004 | 11:49 PM
rev limiter's Avatar
Default Energy Suspension Motor Mount Inserts for jdm ee8/9
Hi i have a 1991 jdm civic ee9 which originally comes with the b16a. No i want to buy some energy suspension motor mounts for the front and the bakc engine mounts. So not the left and right mount. Now i heard that the 90-91 usdm integra has the same engine mounts is this correct and can some one tell for what excact integra i have to order the mounts ??? Thank you very much.
Old Sep 30, 2004 | 10:02 AM
Default Re: Energy Suspension Motor Mount Inserts for jdm ee8/9 (rev limiter)
Old Sep 30, 2004 | 11:26 AM
EtaK's Avatar
up
Old Sep 30, 2004 | 11:37 AM
biggdogg's Avatar
id say 90-93 integra .i have the old-school place racing weld in mounts and it basically converts my car to jdm specs. i used the 90-93 integra mounts .
Old Sep 30, 2004 | 03:00 PM
Default Re: Energy Suspension Motor Mount Inserts for jdm ee8/9 (biggdogg)
any confimation on that ????
Old Oct 7, 2004 | 03:22 AM
up up
Old Oct 7, 2004 | 03:48 AM
SETI20's Avatar
Just use the crx ones....I did. Works fine.
Old Oct 9, 2004 | 06:28 PM
Default Re: (SETI20)
But i have a b16a engine. I have a 1991 civic with the b16a1 engine in it from the factory. Are not the engine mounts from the b16 bigger than from a non vtec crx ??
Old Oct 9, 2004 | 06:54 PM
dingusjt's Avatar
Default Re: (rev limiter)
i'm in the US..but I had bought some energy suspension mounts for my stock civic ED, when i was d-series but i never put them in...then I purchased a EF9 front clip and welded the stock EF9 mounts in.
the energy suspension mounts made for 88-91 Civic/CRX fit the EF9 mounts.
Old Oct 10, 2004 | 03:10 AM
SETI20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev limiter &raquo;</TD></TR><TR><TD CLASS="quote">But i have a b16a engine. I have a 1991 civic with the b16a1 engine in it from the factory. Are not the engine mounts from the b16 bigger than from a non vtec crx ??</TD></TR></TABLE>
Like I said... just se the 90 CRX ones. I have a B16 too.
Old Oct 10, 2004 | 04:06 AM
Bart-EK's Avatar
rev limiter: seti20 is in holland as well... believe the kid... he knows...
Old Oct 10, 2004 | 04:54 AM
SETI20's Avatar
....kid? Don't make me whoop your *** there Bart.
Old Oct 10, 2004 | 05:24 AM
Bart-EK's Avatar
mwuhahaaa.... get into your car, drive for 3 hours and come here so I can kick you in the nuts...
btw: did you throw me the 75? didn't check...
Old Oct 10, 2004 | 01:10 PM
oeps sorry didn't pay attention could hoave so what up seti20. Oke last question. I want the inserts for the front mount. The one on the transmission. And the one at the back of the engine. Do you have the same inserts ?? Is it easy to put them in how does it wordks thanks. You can also explain in dutch hahahaaaa maybe i contact you through slh. latersssss
Old Oct 10, 2004 | 01:17 PM
B16 ED9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">Just use the crx ones....I did. Works fine.</TD></TR></TABLE>
Old Oct 10, 2004 | 03:13 PM
SETI20's Avatar
The engine mount set is a 2 piece set.
The front and the back. No tranny mount.
Because of my swap I do not have a front mount anymore...but on a EE8/EF9 etc it will fit like stock.
In my case the engine was out of the car, wich made installment way easier. But in your case, just unbotlt the mount... push in the bushing, re mount and you're done.
It is also a good ide to completely fill the mount up with polyurethane kit. Not only does it keep the bushing in its place while mounting...it also helps transferring vibrations to the chassis, wich in turn reduces stress on the engine itself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">rev limiter
Offline
73 posts [100%]
the hague
1-4-2004 </TD></TR></TABLE>
D'Oh...you were just another redneck to me
Old Oct 10, 2004 | 11:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">It is also a good ide to completely fill the mount up with polyurethane kit. Not only does it keep the bushing in its place while mounting...it also helps transferring vibrations to the chassis, wich in turn reduces stress on the engine itself</TD></TR></TABLE>
What do you mean ??? Polyurethane kit ?? Zoals een tube tandpasta maar dan gevuld met polyurethane ?? Hoe kom ik daar aan ???
Haha that was some dutch.
Old Oct 11, 2004 | 12:47 AM
SETI20's Avatar
Zwarte PolyUrethane ruiten kit. Verkrijgbaar bij iedere auto materialen zaak.
Old Oct 11, 2004 | 12:55 AM
importboi22's Avatar
wow that looks pretty damn hard to read!!!
SALAT PO!!! theres some tagalog for ya!
Old Oct 11, 2004 | 02:55 AM
Default Re: (importboi22)
Haha oke back to english. How does it work ?? Do i have to remove the original rubber ???
Old Oct 11, 2004 | 02:05 PM
SETI20's Avatar
If you can, remove the mount... squirt glue liberally...push in the mounts. Wipe off excess. Let it set for a day if you can. (not really really nessecary) remount.
Drive!!!
Old Oct 12, 2004 | 01:05 AM
cool no prob thanks for the explaination
truejdm2
Mar 12, 2008 08:30 AM
exhale
Sep 7, 2007 05:30 PM
white_db8
May 26, 2007 09:34 AM
integrawow
Suspension & Brakes
Nov 10, 2006 09:48 PM
kelvinchau25
Jul 20, 2005 03:11 PM
