Purge control solenoid (pcs) wiring for crx. w/obd1 b18c
Old Sep 29, 2004 | 08:41 PM
Rywire's Avatar
Default Purge control solenoid (pcs) wiring for crx. w/obd1 b18c
I just want to make sure I have this wiring right. Im using a obd0-1 jumper made by Jason, and I am using my stock crx pcs. I just de pinned my green wire from the ecu, and wired it to Jason's labled wire. As for the other wire, im assuming that its a ground or a switched power. Which is it? Just curious... And also, if I just leave the black wire un touched it will work, right... because it will be tapped into the harness in the correct place. Right???? Thanks a ton!!
Ryan
Old Sep 29, 2004 | 09:06 PM
dirtydisaster's Avatar
Default Re: Purge control solenoid (pcs) wiring for crx. w/obd1 b18c (droppedcrxsi)
I'm doin' the same project, pretty sure it's a ground
Old Sep 29, 2004 | 09:25 PM
Rywire's Avatar
Default Re: Purge control solenoid (dirtydisaster)
ok, so it should be fine how I have it then... Right?
Ryan
Old Sep 30, 2004 | 09:35 AM
Rywire's Avatar
Default Re: Purge control solenoid (droppedcrxsi)
up
Old Sep 30, 2004 | 12:55 PM
JimBlake's Avatar
I'd have to look it up to be sure, but I believe most solenoids are powered from the main relay, & the ECU closes the ground side of the circuit to energize it.
Old Sep 30, 2004 | 03:05 PM
Rywire's Avatar
Default Re: Purge control solenoid (JimBlake)
Thats what im thinking too, so I believe I have it wired correct. Right?
Projectludatic
May 25, 2010 12:29 PM
dave_ed9
Mar 22, 2005 09:01 PM
egg_baLLa
Mar 5, 2005 11:09 AM
daver
Sep 19, 2003 04:38 AM
eg6hatch
Jul 10, 2003 05:31 AM
