B16 bore and sleeve?
Old Sep 29, 2004 | 08:31 PM
dookieK9's Avatar
Default B16 bore and sleeve?
whats up everybody, i was wondering is it worth boring and sleeving a B16 block.
Old Sep 29, 2004 | 08:32 PM
UnKnownUser's Avatar
Default Re: B16 bore and sleeve? (dookieK9)
What are youre plans?
Old Sep 29, 2004 | 08:37 PM
dookieK9's Avatar
Default Re: B16 bore and sleeve? (AllMotorLsVtecDc4Rs)
i got a b16a motor my head has a port job, i got ferrea valves, crower springs and retainers, and that is what i have so far. the block is still stock.
Old Sep 29, 2004 | 08:38 PM
ok,so no block work?stock pistons?If not really no point....
Old Sep 29, 2004 | 08:40 PM
dookieK9's Avatar
i want to get some piston if i bore the block. the highest ill go would be at least 12:1. im trying tio make a daily driver also.
Old Sep 29, 2004 | 08:46 PM
what kind of pistons an mm?ima be sleeved to 86mm with 14.5:1 cr pistons,so if you have the money extra saftey is nice and maybe even some arp head bolts!
Old Sep 29, 2004 | 08:50 PM
dookieK9's Avatar
i was told that a B16 could be only bore out to 1.9 maybe 2.0
Old Sep 29, 2004 | 08:52 PM
EdBoon's Avatar
You should check out the Tech43 kit.
Old Sep 29, 2004 | 08:57 PM
Default Re: B16 bore and sleeve? (EdBoon)
I only know about 1.8 but im not saying its possible it is well worth possible
Old Sep 29, 2004 | 09:01 PM
dookieK9's Avatar
yea i was thinking of picking up a gsr block if the b16 is not worth boring out
Old Sep 29, 2004 | 09:02 PM
dookieK9's Avatar
is tech43 member or something else? sorry im new to HT
Old Sep 29, 2004 | 09:14 PM
dookieK9's Avatar
nevermind i found what it is thanks
99 sir
Mar 19, 2010 02:12 PM
BukakkEK9
Mar 26, 2007 06:32 PM
xDicktonesx
Aug 6, 2005 09:04 AM
hondapro_2005
Jan 9, 2004 09:23 AM
SpdFrk
Aug 29, 2003 07:42 AM
