Name this part!
Old Sep 29, 2004 | 07:33 PM
blaster834's Avatar
Default Name this part!
Ok i cant get a pic of it but i will explain it. The first one to ring in will get a from me!! I was taking out my Window washer fluid resivor today and i had to take out this polished cylinder, it was hooked up to nothing. I looked like it had something hooked up to it at one time, from the way there was 2 spots that looked not as tranished. Right next to Window washer fluid resivor and PS resivor.
Thanks y0
Old Sep 29, 2004 | 08:12 PM
simplyredvw's Avatar
Default Re: Name this part! (blaster834)
I would almost think the ac drier but only if you have removed the ac from your car recently.
Old Sep 29, 2004 | 08:15 PM
Luserkid's Avatar
Default Re: Name this part! (simplyredvw)
Its for the A/C goes in that little hole right? I guess like said above AC drier, all i know is that its for the AC system.
Old Sep 29, 2004 | 08:17 PM
95sihb's Avatar
give a little more info , what car,what year, what trim ? this will help with naming part
Old Sep 29, 2004 | 08:30 PM
blaster834's Avatar
Ya i think its for the ac system, ac took out of my Si when i did swap. Thanks
95sihb's Avatar
Default Re: Name this part! (95sihb)
What i can think of , is that if you have a/c before you got the car then the silver cylander in called Receiver if you look at the top of it you will see a little bubble glass you look in here to see if your a/c system is low
Old Sep 30, 2004 | 12:42 PM
blaster834's Avatar
ya i know i had ac i took it out at time of swap soo ya thats what it is thanks
Emmanuel Vaz
Jun 24, 2019 08:02 AM
crazyguy
Aug 10, 2007 06:45 AM
Draggin99Si
Dec 29, 2006 05:36 PM
