Switch/Sensor next to oil pressure switch?
What is the switch/sensor next to the oil pressure switch as shown in the picture. The motor is D16a6. I need to know where to plug in the BLK wire and where to plug in the GRN/YLW wire. Wasn't paying attention when I took it out.
Ok so here's the only mention of it in the manual. Testing the dam thing. Says test for continuity between terminals A & B. So does that mean that either terminal will work fine for either wire/plug (solid BLK) or (YLW/GRN).
A & B are fine, but they arent labeled on the sensor. i have mine hooked up however and no problems, but there is a 50/50 chance to get it wrong i guess (if it matters).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eli_vang »</TD></TR><TR><TD CLASS="quote">i dont think it matters which one goes to which right?</TD></TR></TABLE>
What he said. I have hooked it up both ways just to see if it would work with both connections and it did.
cehcivic15
26
Aug 18, 2020 04:57 PM
EJ8CIVIC
Aug 15, 2015 10:47 PM
TheEvilBain_TDB
20
Jul 24, 2009 06:02 PM
civic-si-2000
Jun 19, 2003 11:16 AM
