B18A OBD1 in to EF Hatch
Old Sep 29, 2004 | 07:01 PM
quicksol95's Avatar
Default B18A OBD1 in to EF Hatch
how hard will it be to swap a b18a obd1 motor into my ef hatch
i am getting the whole car and it still runs
so i will have ecu, dizzy and all wiring
can anyone help me out
will i need a obd0 > obd 1 harness?
what else will i need
Old Sep 29, 2004 | 07:12 PM
sloweh3's Avatar
Default Re: B18A OBD1 in to EF Hatch (slowsohccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsohccivic &raquo;</TD></TR><TR><TD CLASS="quote">how hard will it be to swap a b18a obd1 motor into my ef hatch
will i need a obd0 &gt; obd 1 harness?
Well, I swapped a b18a1 obd0 motor in my old EF. First of all, if it's not wired for MPFI, you'll need to wire it for MPFI. Second, you're going to need new motor mounts and shift linkage. Hasport sells them. Either that or ebay should have some. Next, you will either need to re-wire your harness or buy a obd0 to obd1 jumper harness. As I said before, Hasport will sell that too. (Notice how Hasport is becoming your new best friend?)
You are also going to have to cut the front motor mount bracket off of the front crossmember. You may also have to notch it where the exhaust manifold is going to sit, depending on which mounts you got.
Lastly, you are going to have to hammer out where the alternator pulley will sit, due to the bigger DOHC engine, or else the alternator pulley will rub on the fenderwell.
Good luck on the swap. My LS was quick as hell in my EF... damn I miss that car...
Old Sep 29, 2004 | 07:15 PM
Reason's Avatar
I did the same thing, i got the whole car. I just kept mine obd-0 because i didnt want to get the conversion harness. If you want to keep it obd-0 then just get a obd-0 ecu, and distributor. And use your engine harness if its a Si.
Old Sep 30, 2004 | 10:08 AM
quicksol95's Avatar
Default Re: (Reason)
what axles to use?
Old Sep 30, 2004 | 10:34 AM
Steemo's Avatar
Default Re: (slowsohccivic)
match up any b series axles with the corresponding intermediate shaft. if you have the whole car just use the axles out of the integra. everything will plug up unless you have a HF CRX or a STD Civic. If this is the case you will have to purchase new knuckles and hubs but i think maybe just maybe you might be able to use the integra ones but you will have to do more research on that. look at this website it should walk you through the process. http://www.geocities.com/speed...p.htm
good luck take your time do it right and most of all have fun!
Old Sep 30, 2004 | 11:09 AM
quicksol95's Avatar
Default Re: (Steemo)
wow my eyes are shot now
is there any info on swapping a obd1 engine into a obd0 car&gt;
Old Sep 30, 2004 | 11:15 AM
smart monkey's Avatar
if you want to use everything get mount kits. use the si harness and then convert to OBD1 with a jumper and use 90-91 teg injectors so it can go with the resistor box from the civic. this should be the bulk of it.
anthony garces
Sep 2, 2009 08:25 PM
Dasfinc
May 21, 2008 12:19 PM
Wii Love My SVT
Dec 9, 2007 06:46 AM
HtC_SiR
May 26, 2004 12:11 PM
mugenintegra16
Apr 8, 2004 10:26 PM
