Is this a sign of a bad alternator?
Old Sep 29, 2004 | 06:56 PM
Gump's Avatar
Default Is this a sign of a bad alternator?
When ever my car is idling and I turn on my lights with the fog light switch already on the on position, the RPM drops from the normal 750 to around 500 and jumps back up to about a 1000 then settles down to 750 again, but with the fog lights off, the RPM doesn't drop as low, about 700 and back to 750. It's been doing this about 2 weeks now.
Old Sep 29, 2004 | 07:00 PM
SOHCejcivic's Avatar
Default Re: Is this a sign of a bad alternator? (Gump)
not too sure, my alternator went out but i never noticed that. all i noticed was the burning smell and whining...then the ****** caught on fire. still have never heard of an alternator catching on fire....
Old Sep 29, 2004 | 07:02 PM
huntarrr's Avatar
I wouldn't think it's a sign of your alternator. I would think it would be something more electrical such as an ELD (electric load detector) which measures the amount of current and sends a signal to the ECU indicating the amount. The ECU adjusts the idle speed to ensure that a proper voltage is maintained in the electrical system when the engine is idling.
However, that's just a guess, I have no experience with this problem.
Old Sep 29, 2004 | 07:04 PM
Gump's Avatar
It only does this during warm up, and after a while of driving it around, it doesn't do it anymore. Thought it had something to do with my valve adjustment I did last week, cause I had adjusted it a bit tight, but I adjusted it again today with a little more play, and it's still doing the same thing.
Modified by Gump at 9:15 PM 9/29/2004
Old Sep 29, 2004 | 07:48 PM
JD_B18CDX's Avatar
The idle control valve might need some cleaning.
Its function is to maintain correct idle speed depending on engine load such as A/C, electrical load....etc.
If it is sticking or slow to react, you will get some idle fluctions before it settles down.
Old Sep 29, 2004 | 08:16 PM
Gump's Avatar
Default Re: Is this a sign of a bad alternator? (JD_B18CDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD_B18CDX &raquo;</TD></TR><TR><TD CLASS="quote">The idle control valve might need some cleaning.
If it is sticking or slow to react, you will get some idle fluctions before it settles down.</TD></TR></TABLE>I'll clean it out tomorrow, but I have a feeling it isn't that.
AsianCivicRider
Nov 9, 2011 06:43 PM
Boosted EJ2
Feb 6, 2011 11:43 AM
rzz
May 2, 2007 07:48 AM
NFM_Dm
Nov 15, 2004 02:47 PM
B2AMMO
Mar 9, 2004 07:59 AM
