coolant problem...
hey i own a 94 ls... heres the problem, i am leaking coolant. When i look at the engine.... the top of the radiator is wet from coolant... all the way across, on the top. (20 inches or so). my car runs fine though. I lose about an inch of coolant a day, from the overflow tank. the weird thing is that when i check the radiator, even when my overflow tank is bone dry, it is always full right to the top. the car smokes after a decent drive...(10+ minutes), when i stop and turn it off. does anybody know whats up... thanks !
how many miles are on the car? most likely the radiator has a crack in it somewhere. every honda around 120K miles or so (with exceptions) has a cracked radiator that needs replacement. i had the same thing and that was the problem. fix it. late.
Sl0wH0nda
Jun 13, 2013 10:22 AM
hondanewbie8181
Honda Civic (2001 - 2005)
12
Dec 16, 2009 03:56 PM
