Need Help fast Please!
Old Sep 29, 2004 | 06:47 PM
89hbcivicguy's Avatar
Default Need Help fast Please!
this problem is driving me crazy i need to know if it is a timing problem or not.....i am not gettin enough air into the intake......burning rich once you touch the gas it stalls......any help will be appreciated i need this car on the road thanx
Old Sep 29, 2004 | 06:52 PM
drussell4801's Avatar
Default Re: Need Help fast Please! (89hbcivicguy)
auto or manual trans?
Old Sep 29, 2004 | 06:53 PM
manual.....i had a 91 crx si and when u hit the gas the intake sucks ur hand in and this one is getting no air.....its a 89 civic dx with the 1.5l sohc manual transmission and i jsut did the head gasket in it but it did it before i did the head gasket..i jsut baught the car for 600bucks so i wanna find out what the problem is to i can get it in for an e-test
Modified by 89hbcivicguy at 8:15 PM 9/29/2004
Old Sep 29, 2004 | 07:15 PM
does it idle really high?
Old Sep 29, 2004 | 07:19 PM
Default Re: Need Help fast Please! (drussell4801)
no not at all the only other problem i notice is it is burning rich and its almost like when u touch the gas its floodin itself but the plugs arent wet.......but they are black!
Old Sep 29, 2004 | 07:46 PM
and what causes black sparkplugs?
Old Sep 29, 2004 | 07:47 PM
too mcuh fuel.....but in this case it is too much air......because im not gettin the air i need
not enough air sorry
Old Sep 29, 2004 | 08:07 PM
check your compression.
maybe your timing belt skipped a tooth.
Old Sep 29, 2004 | 09:52 PM
SoftieB16's Avatar
if your idle is really low like 300 rpm. theres a lil screw on the throttle body and if u turn it the right way ur rpms magicly go up or down
Old Sep 30, 2004 | 04:46 AM
Default Re: Need Help fast Please! (SoftieB16)
no it does not idle low or high.....its jsut not getting enough air into the intake.....only happen when u touch gas pedal.......when u touch gas pedal its nto getting the aior and it stalls out and takes a while to start again.....no idle problem
Old Sep 30, 2004 | 05:12 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
bad intake air temp sensor? are you throwing a code at all?
Old Sep 30, 2004 | 05:26 AM
crx_88_si's Avatar
measure the TPS voltage.
and do a compression test.
Old Sep 30, 2004 | 03:50 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (crx_88_si)
It sounds like the tps is not working properly or you have a vacuum leak.
Old Sep 30, 2004 | 06:50 PM
Default Re: (mar778c)
i dont know about the tps or intake air temp sensor and compression is 150 on all 4 but im gonna check the timing and redo all the vaccum lines and its throwing code 16 (fuel injection circuit) any other idea's out there for me to check i gotta get this thing on the road
Old Sep 30, 2004 | 07:00 PM
1slohatch's Avatar
take a look under the distributor cap also my car had similar symptoms and it was because the distributor was bad'
Old Sep 30, 2004 | 07:12 PM
Default Re: (1slohatch)
but did it stall when u touched the gas??it idles fine but once u touch the gas it stall and its throwin code 16 soo
Old Sep 30, 2004 | 07:51 PM
Default Re: (89hbcivicguy)
what am i lookin for under the cap?
Old Sep 30, 2004 | 07:58 PM
91civicEX's Avatar
is it dpfi? if its dpfi and one of the injectors is unplugged itll throw that code and cause that problem.
Old Sep 30, 2004 | 08:02 PM
RedRocketCRX's Avatar
my friend had the same problem on his integra when ever he would touch the gas the car would bog down almost to where it would turn off. I did the same thing that you did. i put my hand by the throtle body to if it sucked in my hand and it didnt. It turns out that the timing was off. so check the timing would be a good idea that could be it.
Old Sep 30, 2004 | 08:15 PM
Mugen Dom's Avatar
Default Re: (RedRocketCRX)
man u make about no sense....is it multi point injection or dual point? 2 u changed the headgasket right? did u align the head tdc and crank tdc? this could be ur problem....but im not sure if it did it before u changed the headgasket because your english is a little confusing....oh well thts ok with me but anyhow state ur probelem in one post detailed and maybe we can help u fix it....are ur sparkplug wires in the right order? ur o2 sensor probably screwed up now also....map sensor vaccume lines could be messed up also theres too much stuff that could be wrong shoot
Old Oct 4, 2004 | 07:04 PM
Default Re: (JdMB16Ahatch)
alriht guys i re did the timing and checked ignition timing.......still having the problem.....but something i left out is that when you turn on the key the engline light flickers really fast..and doesnt stop.....so i go to the engine bay and something in the vaccum control and something in the intake is makeing a ticking sound.......makes no sence to me any idea's?
rossyrossb18a
Jul 13, 2006 04:09 PM
alpha_1
Nov 28, 2004 08:18 PM
SIINSI
Jan 16, 2004 07:08 AM
Baby_Blue_Si
Jul 5, 2003 10:25 PM
