Dyno graph of the h23a1 w/ crower stage 1 camshafts and other mods
Old Sep 29, 2004 | 02:47 PM
SUB-0 H23's Avatar
Default Dyno graph of the h23a1 w/ crower stage 1 camshafts and other mods
max power= 161.8
max torque=158.2
modification list:
*home-made CAI
*magnaflo muffler
*IM heat shield
*egr block plate
*bypass cold-start valve
*disconnected the vacuum hose leading to the IAB
*13 degree timing (D'OH)
*CROWER stage 1 cams
*DC header
unlike me, the lude is running rich
i just need to tune the lude and get a full cat-back exhaust ...
Modified by SUB-0 H23 at 4:29 PM 9/29/2004
Old Sep 29, 2004 | 03:00 PM
@ries's Avatar
Default Re: Dyno graph of the h23a1 w/ crower stage 1 camshafts and other mods (SUB-0 H23)
Deffinitely get that sucker tuned. What do you plan on using for fuel management? AFC, Hondata, EMS?
Old Sep 29, 2004 | 03:26 PM
SUB-0 H23's Avatar
Default Re: Dyno graph of the h23a1 w/ crower stage 1 camshafts and other mods (@ries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">Deffinitely get that sucker tuned. What do you plan on using for fuel management? AFC, Hondata, EMS?</TD></TR></TABLE>
im debating on what to get, it is going to be either the SAFC or Hondata... i still need to research the two... what do you recommend?
Old Sep 29, 2004 | 03:41 PM
@ries's Avatar
I'd go with hondata.
Old Sep 29, 2004 | 04:12 PM
Daboi630's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUB-0 H23 &raquo;</TD></TR><TR><TD CLASS="quote"> unlike me, the lude is running rich
LOL!
so that was open header? or OEM exhaust?
Old Sep 29, 2004 | 04:25 PM
darkd1gt's Avatar
wow that gives me some hope i got like half of those mods got the egr plate today gettin cat back next week have high flow cat but no header yet how much u think the cams gave u and what is the 13 degrees mean im not good with timing issues
Old Sep 29, 2004 | 04:59 PM
five-0's Avatar
Default Re: Dyno graph of the h23a1 w/ crower stage 1 camshafts and other mods (mattspivey)
Cool... It's good to see someone with an H23a1 that doesn't have a gazillion dollars invested into their motor posting some dyno results. Kudos. Keep going man, keep going!
-You listed that you have an IM heat sheild... What exactly do you mean? Is it a gasket or what? Pictures?
Old Sep 29, 2004 | 05:06 PM
hOndafienD 04's Avatar
damn das wassup...look at that torque #.....guess the cams really helped a lot...wonder what the stage 2's or 3's will give....damn i cant wait till i have enough for the stage 2's.....i envy you :-)
Old Sep 29, 2004 | 05:09 PM
Hawkze_2.3's Avatar
Default Re: Dyno graph of the h23a1 w/ crower stage 1 camshafts and other mods (five-0)
Good to see a real dyno and good numbers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by five-0 &raquo;</TD></TR><TR><TD CLASS="quote">-You listed that you have an IM heat sheild... What exactly do you mean? Is it a gasket or what? Pictures?</TD></TR></TABLE>
Here---https://honda-tech.com/zerothread?id=951429
Old Sep 29, 2004 | 07:02 PM
jdmaek's Avatar
what do h23s with bolt on, run on the dyno?
Old Sep 29, 2004 | 07:37 PM
SUB-0 H23's Avatar
Default Re: Dyno graph of the h23a1 w/ crower stage 1 camshafts and other mods (Daboi630)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daboi630 &raquo;</TD></TR><TR><TD CLASS="quote">
so that was open header? or OEM exhaust?</TD></TR></TABLE>
oem cat, resonator, and piping... only the muffler is aftermarket
Old Sep 29, 2004 | 07:48 PM
SUB-0 H23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattspivey &raquo;</TD></TR><TR><TD CLASS="quote">wow that gives me some hope i got like half of those mods got the egr plate today gettin cat back next week have high flow cat but no header yet how much u think the cams gave u and what is the 13 degrees mean im not good with timing issues </TD></TR></TABLE>
normaly i have the timing set at 13 degrees cause of nitrous... but i forgot to advance the timing for the the dyno run ... basically advancing the timing = more hp, to a certain point
Old Sep 29, 2004 | 07:52 PM
darkd1gt's Avatar
oh how do u adjust it, by the dist, or do u have any cam gears. u must have a timing gun?
im a post ***** lol. at least this time i used punctuation. aol has reuiened me, im just so dang popular.
Old Sep 29, 2004 | 07:57 PM
AndyD's Avatar
Damn, VERY impressive!! Good work!!
Old Sep 29, 2004 | 08:46 PM
PirateMcFred's Avatar
Awesome numbers for retarded timing, relatively low compression, and stage one cams untuned. Holy crap! Now you need to tune it and spray and you can pull some awesome times! Congrats.
Pirate
Old Sep 29, 2004 | 09:01 PM
red92si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattspivey &raquo;</TD></TR><TR><TD CLASS="quote">oh how do u adjust it, by the dist, or do u have any cam gears. u must have a timing gun? .</TD></TR></TABLE>
If you are OBD-I then you can adjust ignition timing by rotating the distributor. Use a timing gun and find the marker on the flywheel (I added a dot of White-Out on the flywheel marker to make it more obvious), and adjust timing. Stock is 15° +/- 2° at idle. I have mine set to 17° at idle, so it's still within spec, but I benefit from the 2° advance.
Old Sep 29, 2004 | 10:34 PM
Mr.Dew's Avatar
Yep, it's Eric.
damn i tried calling ur @zz to congradulate but u don't answer.. but anyways nice numbers i think those cams + keeping your intake cool worked wonders.
Old Sep 30, 2004 | 06:03 PM
SUB-0 H23's Avatar
Default Re: Dyno graph of the h23a1 w/ crower stage 1 camshafts and other mods (oNeMoBB1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">Awesome numbers for retarded timing, relatively low compression, and stage one cams untuned. Holy crap! Now you need to tune it and spray and you can pull some awesome times! Congrats.
Pirate</TD></TR></TABLE>
yeah man, 13's here i come
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oNeMoBB1 &raquo;</TD></TR><TR><TD CLASS="quote">damn i tried calling ur @zz to congradulate but u don't answer.. but anyways nice numbers i think those cams + keeping your intake cool worked wonders.</TD></TR></TABLE>
whoops, i missed your call, but yeah thanks dude and everyone else that posted
Old Sep 30, 2004 | 09:02 PM
4thGenReady2Go's Avatar
162? The dyno shows peak hp around 145 or so, or is that an old dyno and one of the dead links is your recent one?
Old Sep 30, 2004 | 09:21 PM
SUB-0 H23's Avatar
Default Re: Dyno graph of the h23a1 w/ crower stage 1 camshafts and other mods (4thGenReady2Go)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thGenReady2Go &raquo;</TD></TR><TR><TD CLASS="quote">162? The dyno shows peak hp around 145 or so, or is that an old dyno and one of the dead links is your recent one?</TD></TR></TABLE>
yeah, the new graph is not showing up
*edit: just notice that there are three po.com members up in here, woOt
mail it to me, I'll host it for you
creizlein
Engine Management and Tuning
Mar 19, 2019 12:12 PM
NirVTEC
Mar 8, 2007 06:01 AM
LSTEG96
23
Oct 21, 2004 12:46 PM
AlexLude
Mar 13, 2004 10:34 AM
