noise coming from the right wheel
I have a problem, i just recently change my axle into a new axle, bolted everything in place, the wheel is bolt tight. So my main concern is that when i drive it makes a loud CLICKING NOISE, so i don't know what it is, whoever might know of this problem please HELP.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraB18LS »</TD></TR><TR><TD CLASS="quote">yea, def. check ur wheel bearings or hub. is it while ur turning or just straight driving?</TD></TR></TABLE>
time to hijack...
same thing happening
but it does it in N
but in gear it doesnt pop
(passenger side)
time to hijack...
but it does it in N
(passenger side)
i just had my wheel bearings replaced and my hub also. no noise whatsoever anymore. also if your car is way to low, which mine was, you might wanna try raising it. maybe certain parts are under too much stress.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSBOI »</TD></TR><TR><TD CLASS="quote">also may wanna check your fender wheel liner was making the same noise found out that it was rubbing the liner </TD></TR></TABLE>
Good call
, i cut my lining out also because of noise and it helped.
Good call
4door93civic
13
Feb 18, 2008 07:19 PM
Brewer
Suspension & Brakes
18
Aug 20, 2006 09:19 AM
