SRS light, Where to put the resistor.
I understand that if theres an SRS unit missing then the SRS memory cannot be reset, I know that if you use a 2.2 ohm resistor in the SRS harness that goes under the steering column you can fool the computer in to thinking there is an SRS device plugged in, my question (and I did do a search) is where does the resistor plug exactly? where on the terminal? does anybody have any pics they can show me?
Thanks
Thanks
https://honda-tech.com/zerothread?id=264288
Your welcome.
Your welcome.
bump this post, the link did not say anything about where to put the resistor.
i guess the srs light comes on after resetting it since it cant detect a airbag in the steering wheel, right?
eJone powereD
16
May 23, 2010 08:57 PM
KND
Apr 26, 2007 08:52 AM
