If I can use the front calipers off a TL or a NSX, what do I do with the rear?
Old Sep 29, 2004 | 01:24 PM
breathinez's Avatar
Default If I can use the front calipers off a TL or a NSX, what do I do with the rear?
I mean I know the brakes up front do like 80% of the stopping but is there anything I can do to the rear? Would the rear calipers off eiter of those two cars fit my 5th gen? The factory ones look so little.
Old Sep 29, 2004 | 02:51 PM
satan_srv's Avatar
Default Re: If I can use the front calipers off a TL or a NSX, what do I do with the rear? (breathinez)
you can't use TL calipers.
You don't need to do anything about the rears.
Old Sep 29, 2004 | 03:30 PM
connvict's Avatar
on that note, i was curious if it were possible to run the RSX type-S calipers on the 5th gen?
From what i understand, those calipers are bigger than NSX, Legend, and/ or Tl......
Old Sep 29, 2004 | 06:30 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: (connvict)
do u gotta mod something or they just bolt up?
Old Sep 29, 2004 | 07:13 PM
IAluder95's Avatar
Default Re: (raylude)
so do NSX caliper fit a 4th gen?
Old Sep 29, 2004 | 08:54 PM
SUB-0 H23's Avatar
just replace the rear pads w/ ceramic ones and you will be all set
Old Sep 29, 2004 | 09:17 PM
Taikonaut's Avatar
Default Re: (SUB-0 H23)
Yes as far as I know NSX and Legend calipers will work on 4th gens. Problem is finding them =P
Old Sep 29, 2004 | 09:20 PM
Kal's Avatar
Kal
ummm.. type-s calipers are not better than the NSX ones.
Maybe the dc5-R brembos but that's about the only way it could be better.
Old Sep 29, 2004 | 10:44 PM
IAluder95's Avatar
Default Re: (Kal)
is there any upgrade to stock calipers. i got new rotors and pads, i just want new calipers. but they are all for big brake, which mean i got to replace all my new parts.
so what im asking is does wilwood or brembo make 4pot replacements i can use with stock rotor size?
FG Two
Apr 2, 2005 09:42 PM
mhgleitz
Dec 17, 2004 05:47 AM
Solscud007
Dec 8, 2004 10:00 PM
bb6h22a
Mar 11, 2003 10:08 PM
kevie88
May 24, 2002 09:57 PM
