See if you EF guys can answer this..
Old Sep 29, 2004 | 01:23 PM
85mm LS VTEC's Avatar
Default See if you EF guys can answer this..
I have a LS/VTEC swap going into my EF, and I am using saturated injectors. Is there a wiring guide you can recommend for me to wire up my motor? Thanks.
Old Sep 29, 2004 | 01:43 PM
hatchback_al's Avatar
Default Re: See if you EF guys can answer this.. (85mm LS VTEC)
why not just use the peak and hold injectors with your stock resistor box
Old Sep 29, 2004 | 02:10 PM
Default Re: See if you EF guys can answer this.. (hatchback_al)
I don't have a resistor box and nobody makes peak and hold injectors big enough for my setup. Anyone else?
Old Sep 29, 2004 | 02:18 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 85mm LS VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I don't have a resistor box and nobody makes peak and hold injectors big enough for my setup. Anyone else?</TD></TR></TABLE>
What size injectors do you need?
Lots of people use the DSM injectors for turbo and your LS/VTEC needs more than that?
What wirign do need help with?
Only the injectors or what?
Old Sep 29, 2004 | 03:23 PM
mildly.interesting's Avatar
add the resistor box, use a D series under-hood harness. I did that on 720cc injectors.
Old Sep 29, 2004 | 04:09 PM
CRX T-Si's Avatar
What you meant to say was "I have these saturated injectors already for my setup but just need to know how to wire them"
Old Sep 29, 2004 | 04:15 PM
Default Re: See if you EF guys can answer this.. (CRX T-Si)
OKAY, then how do I wire up saturated injectors?
Old Sep 29, 2004 | 04:22 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
i thought all you had to do was connect all the wires going to the resistor box...in essence just remove the extra resistance from the wiring (the saturated injectors are higher resistance - no need for the box).
ive never done this, so i never really paid attention to the 50 posts ive seen about how to do it. theres probably more to it than this...
Old Sep 29, 2004 | 04:36 PM
HamiltonRex's Avatar
Saturated
Peak hold
Old Sep 29, 2004 | 04:39 PM
kur0ryu's Avatar
This is what I did if my memory serves me correct. There should be a green plug connected to the resistor box. 4 wires come from the injectors to the box. there should also be a wire running to the main relay. So there's a total of 5 wires running to the relay box. What you want to do is sever all 5 wires and solder them together, then wrap it with electrical tape. You're done and you can use saturated injectors now. If you're using your original EF wire harness you may need to change the injector clips to fit the saturated injectors.
Basically, your injectors have two wires. 1 coming from the main relay (the 12 volt signal) then 1 goes to the ECU. when the ECU wants the injectors to spray, then it grounds the wire to complete the circuit, and activates the solenoid in the injector to allow it to spray. With peak and hold, they need the resistor box to lower the 12volt signal. when going to saturated, they can handle the 12volt signal, so you just solder all 5 wires together and call it a day.
Modified by kur0ryu at 9:07 PM 9/29/2004
Old Sep 29, 2004 | 05:01 PM
ihateslowhondas's Avatar
go to homemadeturbo.com they have a how to on dsm injector. that might help
Old Sep 29, 2004 | 06:06 PM
Eggman's Avatar
simply cut all the wires going to your resistor box, and solder them all together.
Old Oct 1, 2004 | 03:40 PM
kur0ryu's Avatar
Default Re: See if you EF guys can answer this.. (Eggman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eggman &raquo;</TD></TR><TR><TD CLASS="quote">simply cut all the wires going to your resistor box, and solder them all together.</TD></TR></TABLE>
Exactly
Old Oct 1, 2004 | 03:48 PM
rjay8604's Avatar
Default Re: See if you EF guys can answer this.. (kur0ryu)
coudln't you just remove the resistor box and run the power to the injectors.
Old Oct 1, 2004 | 03:54 PM
kur0ryu's Avatar
Default Re: See if you EF guys can answer this.. (rjay8604)
Thats exactly what severing all 5 wires and soldering them together would do.
Old Oct 1, 2004 | 04:22 PM
zCivic's Avatar
yep take the 5 wires and connect them together. If you have a xtra 5 pin square plug can make a nice little jumper plug or just cut and solder or crimp. Generally peak/hold (low impedence) have quite a bit large fuel delivery
Fuel injectors NEW
available for turbo / all motor applications. For honda / acuras. unlike other shops, our injectors are MACHINED to jus slap into to your beast. (HI IMPEDENCE) SATURATED
LUCAS 310cc $220
LUCAS 370cc $220
LUCAS 440cc $225
RODCHESTER 525cc $279
SEIMEN 580cc $289
(LOW IMPEDENCE) Peak and Hold
RODCHESTER 650cc $285
SEIMEN 740cc $290
RODCHESTER 780cc $290
SEIMEN 850cc $295
RODCHESTER 880cc $299
RODCHESTER 1000cc $325
BOSCH 1600cc $335
copied from camp1320.com
Old Oct 1, 2004 | 10:30 PM
rjay8604's Avatar
Default Re: See if you EF guys can answer this.. (zCivic)
oh, you meant solder the power to all the injector wires, pretty much bypassing the inj. resistor, but then you can take that bad boy out, its unnecessary after that.
Old Oct 2, 2004 | 07:59 AM
kur0ryu's Avatar
exactly, once you solder all the wires together, you can remove the resistor box from the car.
CivicxTree754
Aug 26, 2008 12:48 PM
LSej1
May 20, 2008 09:13 PM
Sassafrass
Oct 9, 2004 09:58 PM
boonacka
Sep 16, 2003 01:16 PM
twkdCD595
Apr 20, 2003 02:06 PM
