Check Engine Light Codes -Please help
I have been running a Check Engine Light on my 02 EP-3. It has 105,xxx miles on it. I went to Advance Auto parts and used their computer and here is what the readout says.
DTC (Codes)
P0341
Camshaft Position
Sensor A - Bank 1
CKT Range/Perf
P0420
Catalyst Efficiency
Below Threshold
(Bank 1)
DTC Pending(Codes)
P0420
Catalyst Efficiency
Below Threshold
(Bank 1)
So, what does this mean? Are the two codes related? Do I simply need a new camshaft position sensor? Where is the camshaft position sensor?
The engine runs perfect. I recently changed the plugs and air filter (3-4mpg increase).
But it was giving me the check engine light off and on before I did the tune up.
Thanks for the help.
DTC (Codes)
P0341
Camshaft Position
Sensor A - Bank 1
CKT Range/Perf
P0420
Catalyst Efficiency
Below Threshold
(Bank 1)
DTC Pending(Codes)
P0420
Catalyst Efficiency
Below Threshold
(Bank 1)
P0341 is actually a problem with VTC.
you need a service manual if you don't already have one. worthwhile investment especially with high mileage
noahsmommy98
Nov 27, 2006 08:30 PM
