ecu fuse is blowing! could it be the main relay?
Old Sep 29, 2004 | 12:30 PM
yusoslo's Avatar
Default ecu fuse is blowing! could it be the main relay?
Getting on the highway My car just died,and would keep blowing every ecu fuse I put it.
My 02 sensor wires where melted 2 days ago and need to check that first.
but could a main relay cause this problem, eversince I put in my new injectors and walbro pump the main relay acts funny. It wont start after its been running if I shut it off and restart it within 5 mins.
anyways Im in a rush but any help would be great.
I have a multimeter and a continuity tester, how could I use these to find my problem
Old Sep 29, 2004 | 01:33 PM
Red Bull's Avatar
Default Re: ecu fuse is blowing! could it be the main relay? (yusoslo)
check to see if u have any loose grounds/wires at the main relay and by your ecu that was the problem for me.
Old Sep 29, 2004 | 02:20 PM
torr's Avatar
Default Re: ecu fuse is blowing! could it be the main relay? (RpwrdTurbocoupe)
definetly check you o2 wires, i kind of had they same problems and it was my secondary o2 sensor wires. they kept shorting to the exhaust and shift linkage.
sometimes the speedo worked sometimes not.
Old Sep 29, 2004 | 05:33 PM
yusoslo's Avatar
Default Re: ecu fuse is blowing! could it be the main relay? (torr)
thanks for the input guys, im just waiting for some daylight to fix this ****, then I can go boost again!!!
eg8_civic_253
Apr 30, 2025 10:21 PM
rlembitz
Dec 14, 2010 03:11 PM
RMXmitch
Nov 1, 2007 03:46 PM
Racewerkz
Dec 12, 2006 12:01 PM
93turbo16
Jun 18, 2006 12:19 PM
