Cd player install in a CRX
So how hard is it to install a Cd player into the CRX? I have done an integra before but I just want to know if the CRX is much different. If anybody has any step by step instructions that would be great. Thanks guys
Needs to be About 20% Cooler
i think the integra and crx use the same plug
assuming ur talking about a 2nd gen crx.
i would get a mitia plug. there a factory plug that plugs into the origional harness and all the wires are labled. when i instaled my awia, i pluged it in and color matched the wires and it worked first time.
trust me, get the mitta plug it's worth it not havoing a hays manual to say what the wires are and having to cut the factory plug off.
assuming ur talking about a 2nd gen crx. i would get a mitia plug. there a factory plug that plugs into the origional harness and all the wires are labled. when i instaled my awia, i pluged it in and color matched the wires and it worked first time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 »</TD></TR><TR><TD CLASS="quote">trust me, get the mitta plug it's worth it not havoing a hays manual to say what the wires are and having to cut the factory plug off.
It's Metra
</TD></TR></TABLE>It's Metra
no its very easy...i did it im my 89 Dx and because of the space for the CD player...you dont need a fillkit or anything....all u need are the 2 plugs you can get from pepboys or circuit city and thats it...the antenna will go right in....no need to take off whole center console unless you wanna run RCA's for a system
well when i did it, the previous owner had cut off the factory plug so i had to wire the american colored wire to japan colored wires! that was fun
but i got through it. if you can just but that conversion plug, it would make thinks just as easy as the teg.
It's the easiest install I've ever done to any car. The console comes out easily and you can access the back of the radio easily. The car is small so you can run custom speaker wires to the speakers without a problem but the factory wiring is sufficient.
RiskEverything
Audio / Security / Video
Jan 8, 2008 05:32 AM
