squeeking
posting for a freind
-eg with b16 swap
we did the swap a month ago, and yesterday when he turned on his some belt would squeek really loud for a split second. the next day it would last longer and would squeek alot louder. we dont know which belt it is, timing belt isnt rubbing the valve cover, ps and alt belt arent rubbing against anything?? any ideas??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe »</TD></TR><TR><TD CLASS="quote">serpentine belt</TD></TR></TABLE>
Not on a I4 those are usually on cars with 2 heads.
When a belt squeeks it usually means its to tight or to loose. Right loosinging it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">
When a belt squeeks it usually means its to tight or to loose. Right loosinging it up. </TD></TR></TABLE>
damn, that sucks cuz on of the belts is tight and the other is kinda loose. how can u tell exactly which one it is?
Aight for both of you (99bb6 and allmotorEG-SI) the way that i test my belts is by pushing my finger down on the belt. I usually leave about a 1/4 of a inch cushion for the belt and it seems to work great. Just loosen it up and pull it to tighten the pully, put your thumb on it and push down, then pull to make the belt tighter and put tention to it and tighten and you should be good to go. Hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorEG-SI »</TD></TR><TR><TD CLASS="quote">well my alt belt is really tight. Think the alt itself could be going bad?</TD></TR></TABLE>
Thats probably why it squeeks. If the belt is to tight it will squeek, if its to loose it will squeek.
If you know for a fact its really tight then thats why its squeeking.
It squeeks for a second right, like you press the throttle and its gone?
thats wierd that it would suddenly be tighter and need to be loosened. By the way, how do I adjust the belts. I'm assuming there is a belt tensioner that I will need a larger breaker bar to put on it and adjust it by loosening a bolt and tightening it at the right setting. This is just a guess though. Is it right?
my alternator belt is too tight... although it sounds nothing like a squeek... it sounds more like a high pitch whining sound... and it happens when i step on the gas... at idle you cant hear it at all... and i figure it makes the whining sound always when i step on the gas... its just that the engine gets loud enough to cover the sound after about 2k....
just havent gotten around to loosening it yet
sounds like the diodes are going bad inside your alt ,could also be the bearing though. some belts sqeak due to dryness, if you put a dab of rubber friendly lube on the ribbed side (sil-glyde) it will stop the sqeaks. thats assuming the belt is properly tight and in good condition.
Dude 1200 posts and you don't know how to adjust your alternator belt?
-Looking towards the front end of the car
-Under the intake manifold on the right side of the engine bay
-Your alternator is here, and it is held on by one bolt on the bottom, and a bolt on the top, that is the tensioner
-You must loosen both bolts (you may need a breaker bar... just for the sake of getting in there). The top is relatively easy to get to, the bottom you will have to get at under the car.
-Once both bolts are loosened, the alternator should move within the tensioner bracket.
-Get it to where you want it, and tighten the bolts back up.
-Have a
-Have a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Did you adjust the belts? </TD></TR></TABLE>
yeah i adjusted/loosened my belts today. still the same. when i turn it on it squeeks, and between 1-2000 rpm it will squeek.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sedanman »</TD></TR><TR><TD CLASS="quote">sounds like the diodes are going bad inside your alt ,could also be the bearing though. some belts sqeak due to dryness, if you put a dab of rubber friendly lube on the ribbed side (sil-glyde) it will stop the sqeaks. thats assuming the belt is properly tight and in good condition.</TD></TR></TABLE>
how do i know if its the diodes in my alt are going bad?
how do i know if its the bearings?
what type of rubber freindly lude do you recomend? this is getting really annoying!
