do i need to jack up the car to install front strut bar?
Old Sep 28, 2004 | 09:07 PM
tsdenny's Avatar
Default do i need to jack up the car to install front strut bar?
^ what the title says .. or is it better to jack it up. ill be installing the t/cls front strut bar.
Old Sep 28, 2004 | 10:24 PM
sj993's Avatar
Default Re: do i need to jack up the car to install front strut bar? (6thgensohcvtec)
I don't think so. I believe a front strut bar connects the top of the two shock towers together. Correct me if I'm wrong.
Old Sep 28, 2004 | 10:36 PM
blueeg's Avatar
Default Re: do i need to jack up the car to install front strut bar? (sj993)
no u dont
Old Sep 28, 2004 | 10:54 PM
tsdenny's Avatar
Default Re: do i need to jack up the car to install front strut bar? (blueeg)
ok, thanks. i was told if relives the pressure if the wheels are off the floor, but i didnt think it was necessary or a must.
Old Sep 28, 2004 | 11:24 PM
cd5_2NR's Avatar
NO...but you can if you want to...
Old Sep 29, 2004 | 04:34 AM
iakona's Avatar
it may not line up properly if you don't. but try it. if it doesn't fit, then jack it up and it should fit.
Old Sep 29, 2004 | 09:03 AM
Eddiebx's Avatar
u want to becareful when jacking it up because you risk having the struts fall out of the upper mount hole because you need to unbolt the 3 bolts for the strut hats.
JDMFreak_DC2
Jan 26, 2009 06:35 PM
MechEng
Dec 29, 2008 09:40 PM
mrdeadman
Apr 20, 2006 04:24 PM
h22vt
Mar 21, 2006 03:49 AM
wizzards581
Feb 10, 2002 08:19 AM
