OT: How do i clean my tranny casing?
clean inside the tran where the clutch goes. my tranny has been sitting in the garage for a year and it has some spiderwebs in it so i just wonder if i could use some water and maybe this steamer thing to clean inside and outside
thanks
thanks
Whats in it? What do you need a cleaner to clean? You should be able to use Engine bright in the bellhousing. Wipe it down with a clean shop rag. should be good as new!
meh. paper towels
i don't think it necessarily needs to be squeaky clean or anything. just make sure that there's nothing in there to actually get on the clutch assy.
geez i didn't see you guys reply~~
yeah that thing contains water in it that's all
so basically i am going to use steam hot water to spray my tranny and inside as well (clutch housing) now my engine and tranny is apart and there are webs in it so i just want to spray it and make it real clean. can i do that?
thanks
thanks
