HCP mounts
Old Dec 12, 2001 | 03:32 PM
kahren's Avatar
Default HCP mounts
was wonderign how muchteh HCP mounts were with shift linkagefor a crx trying to put LS motor in...
Old Dec 12, 2001 | 03:42 PM
customx_'s Avatar
New User
Default Re: HCP mounts (kahren)
ok i dont understand what your asking
Old Dec 12, 2001 | 03:46 PM
Max_ED9's Avatar
Default Re: HCP mounts (mindtrix)
he is asking how much for HCP motor mounts for a b18 swap...
and i think they go for 425 with the shift linkage....
[Modified by maxracing, 12:47 AM 12/13/2001]
Old Dec 12, 2001 | 03:52 PM
customx_'s Avatar
New User
Default Re: HCP mounts (maxracing)
try $415 w/ linkage from blown90hatch
Old Dec 12, 2001 | 04:19 PM
rioninja's Avatar
hey kahren, go with HCP.
Old Dec 12, 2001 | 04:37 PM
jaje's Avatar
hcp engineering has 4 mounts to hasports 3 (both are good mounts...quality and well engineered) but for me 4 is better than 3, helps to reduce axel breakage
Old Dec 12, 2001 | 10:57 PM
Blown90hatcH's Avatar
Default Re: HCP mounts (jaje)
410 shipped from me. 4 eurathane mounts with adjustable shift linkage. Let me know.......Jason
Old Dec 13, 2001 | 12:30 AM
AfEn808's Avatar
New User
Default Re: HCP mounts (Blown90hatcH)
i was just wondering how hard would that front mount be to intall on my ef8.
Old Dec 13, 2001 | 05:07 AM
Doodoo's Avatar
Default Re: HCP mounts (AfEn808)
You have to shave a bit of the mount on the front crossmember. I did mine with a dremel, test fit, dremel. 5 mins, done.
Old Dec 13, 2001 | 12:23 PM
t04ef's Avatar
New User
Default Re: HCP mounts (Doodoo)
Yeah, I got one on suggestion from blownhatch, and suggested to a guy I knew that he do the same.
We did his swap about 2 weeks ago and so far the mounts seem to hold up pretty good.
Only problem he had was with the shiftlinkage nuts. They'd come loose after about an hour of driving, so we just put a few little "tack" welds around it and it hasn't done it again.
I was surprised too, the car didn't vibrate as much as I thought it would....
they're some beefy mounts though...
Old Dec 13, 2001 | 01:43 PM
samiam's Avatar
Man i need a mount kit BAD! I just got my b16a yesterday and prepping her up right now for the swap.BUT! i have a few ?? i have the y1 trans but no intermediate shaft. I was told to use 90-93 integra axles and intermediate shaft. Does it make a difference if its manual or auto? need some help here guys.
Blown 90 hatch.. will it still be $410 shipped to honolulu hawaii? if so we need to make arrangements.
Old Dec 13, 2001 | 01:50 PM
rioninja's Avatar
Default Re: HCP mounts (samiam)
Yeah, just go with the 90-93 integ stuff. You can use 94+ axles and int shaft, but you will also need the appropriate seals for the trans. Automatic int shafts are different, and wont work. Check out www.hasport.com/axles
Old Dec 13, 2001 | 01:59 PM
samiam's Avatar
Default Re: HCP mounts (RioNinja)
Cool thanks rio! so if i use 94 up axles i need to change the axle seals on the trans ? OK! Right got it! thanks man!
Old Dec 13, 2001 | 02:10 PM
rioninja's Avatar
yes, but remember thats only with a 94+ intermediate shaft as well. You'll see the difference if you look at them in person. (actually the passengers side doesnt matter, as long as you get the correct seal. ex: you could use a 90 passengers side axle, and 95 intermediate shaft and drivers axle)
Old Dec 13, 2001 | 06:02 PM
kahren's Avatar
i need a d16a6 BAD, if someone is local and selling one please let me know!!!
i am in CT
Old Dec 13, 2001 | 07:06 PM
PM me your address and I will readjust the shipping for you. Thanks-Jason
Old Dec 13, 2001 | 08:23 PM
samiam's Avatar
honolulu hi 96797
Old Dec 13, 2001 | 09:43 PM
Hey man....45 bucks to ship it to HI so it would be:
435 shipped to 96797. Email me if intereseted.
Turbo_Ef@yahoo.com
Jason
Old Dec 16, 2001 | 08:28 AM
iwhichisme's Avatar
i have that kit and cant figure out how to use the front mount, it seems they dont mate up.
Old Dec 16, 2001 | 09:14 AM
rioninja's Avatar
Default Re: HCP mounts (iwhichisme)
Easy, you have to trim some of the mount off (about a half inch or so depending), and drill another hole.
sloed9si
May 21, 2009 03:04 PM
91EF_Si
Sep 27, 2007 07:09 PM
B16CRXT
Nov 27, 2004 12:21 PM
bluecrxsi
10
Feb 4, 2003 01:38 PM
civicguy
Feb 2, 2002 11:26 PM
