PNP GSR head Skunk2 everything, problems
Old Sep 28, 2004 | 04:55 PM
pokemon's Avatar
Default PNP GSR head Skunk2 everything, problems
Timing is on, valves adjusted to spec drives normal before vtec, once it hits VTEC it falls on its face. Anyone know what the problem could be? Skunk2 Stage 2 Cams, Skunk2 Cam Gears, Skunk2 Intake Manifold, Retainers, Springs, and Valves. TIA
P.S. Stock fuel system and ecu
Old Sep 28, 2004 | 05:08 PM
1stGENGSR's Avatar
Default Re: PNP GSR head Skunk2 everything, problems (pokemon)
It's your 'STOCK' ECU! I had everything you do (except I ported and polished my stock manifold) and I did the same thing when I rebuilt my motor and ran a stock ecu for a while.......Let's just say it ran like **** (felt better without VTEC) up until I sent the ecu to Skunk and got it reprogrammed............Lesson learned..................................
Old Sep 28, 2004 | 06:41 PM
95 integra's Avatar
Default Re: PNP GSR head Skunk2 everything, problems (1stGENGSR)
you're going to need to move that vtec pt to around 5800 or something like that.
Old Sep 28, 2004 | 07:01 PM
gt35r's Avatar
Default Re: PNP GSR head Skunk2 everything, problems (95 integra)
yep
Old Sep 28, 2004 | 08:50 PM
shermanyang's Avatar
Default Re: PNP GSR head Skunk2 everything, problems (ubehatin)
OMFG....not to be an *** or anything bro, but you've got such a sweet setup and you're trying to run it on a stock ecu and fuel system? you can't go half *** when it comes down to fuel and tunning! that's where all the power is found!!
Old Sep 28, 2004 | 09:59 PM
riceball777's Avatar
your problem is your low vtec crossover point
Old Jan 25, 2009 | 07:09 PM
94VTEC2TONE's Avatar
im probably gonna sound like a dick or something. but you put enough time into putting in cams retainers and all that and just let it run on a stock ecu. your asking for trouble. tune it and then see how it feels
krnboynemesis
Jul 4, 2005 11:13 AM
racinghb
Aug 29, 2003 01:59 PM
WorkForHonda
Apr 11, 2003 04:17 PM
strils
Oct 6, 2002 05:49 AM
C4wrx
Mar 5, 2002 04:49 AM
