engine wont fire
Old Sep 28, 2004 | 04:22 PM
hopsta's Avatar
Default engine wont fire
I hooked up a new stereo system with a 1000 watt amp. The car ran fine after the install. The very next morning the car wouldnt fire up. It sounded like it wanted to, it cranked and everything....but just wouldnt do it.
Could it be the ECU, alternator, starter, or ignition coil in the distributor?
It seems like the whole problem might be blown from the amp being on.
Old Sep 28, 2004 | 04:26 PM
sl33pyelmo's Avatar
Default Re: engine wont fire (hopsta)
did you check the battery?? maybe you hooked up the system wrong.. check the remote and battery wire on the amp.. if its trying to turn over but can't, then there not enough juice to start the car...
Old Sep 28, 2004 | 05:44 PM
bsballboyjk's Avatar
yea i agree. i dont think it has to to with the stuff you installed. sounds like a battery problem. only think i can think of with the amp is if you accidently dont have the battery hooked back up right with the amp attatched
good luck!
Old Sep 29, 2004 | 04:01 PM
hopsta's Avatar
Default Re: (bsballboyjk)
it still wont start.....i gotta new battery put in and it still wont start. Also after a few days of not running its sounds even worse. I found that im not gettin any spark to my spark plugs
jdm.swift
Audio / Security / Video
Aug 13, 2010 06:56 PM
Michael.K.Conte
Jun 6, 2010 06:32 AM
Birdley42008
Jul 20, 2007 04:07 PM
ferby
Jun 11, 2005 08:16 AM
GroundZer0 336
13
May 23, 2003 06:10 AM
