just SEAFOAMED my engine at 202,500mi
Old Sep 28, 2004 | 03:56 PM
Shelton's Avatar
Default just SEAFOAMED my engine at 202,500mi
i just bought 88 crx si and it was laggy all over the idle was crap so i just seafoamed today the car has just about 202,500mi! i read on blown head gaskets and all but whatever.. the difference was instant. i will leave it in the oil for 1k and then change it but the stuff gets a fat from me!. wow late tonight i steped on the gas and the response is 100% better
Modified by Shelton at 5:03 AM 9/29/2004
Old Sep 28, 2004 | 04:03 PM
B2FiNiTY's Avatar
Default Re: just SEAFOAMED my engine at 202,500mi (Shelton)
What could you tell?
Old Sep 28, 2004 | 07:52 PM
Nevaeh's Avatar
What the hell i seafoam?
Old Sep 28, 2004 | 08:04 PM
Shelton's Avatar
Default Re: just SEAFOAMED my engine at 202,500mi (Nevaeh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nevaeh &raquo;</TD></TR><TR><TD CLASS="quote">What the hell i seafoam?</TD></TR></TABLE> cleans the engine from carbon build up and crap... good stuff!
Old Sep 28, 2004 | 08:05 PM
Shelton's Avatar
Default Re: just SEAFOAMED my engine at 202,500mi (B2FiNiTY)
thats the seafoam worked great i have better throttle response my car even though its a d right now is quicker than it was! the stuff work awesome even on the high milage car that i have
Old Sep 28, 2004 | 08:29 PM
RAB's Avatar
RAB
I've heard of some MR2 owners doing this. Interesting stuff. Plumps of smoke come out from exhaust for about 10 minutes.
Old Sep 28, 2004 | 08:30 PM
Quik89Si's Avatar
Interesting. Never heard good reviews from this stuff, may be worth a shot.
What exactly do you do with it? Put it in the oil? Run it through the gas tank?
Alex
Old Sep 28, 2004 | 09:31 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Default Re: just SEAFOAMED my engine at 202,500mi (Quik89Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik89Si &raquo;</TD></TR><TR><TD CLASS="quote">Interesting. Never heard good reviews from this stuff, may be worth a shot.
Alex</TD></TR></TABLE>
I wanna know too
Old Sep 28, 2004 | 09:44 PM
Donkey85's Avatar
Default Re: just SEAFOAMED my engine at 202,500mi (MR.RED'89)
do a search on seafoam there is gobs of info on threads its great stuff
Old Sep 28, 2004 | 10:01 PM
CRseXy's Avatar
Default Re: just SEAFOAMED my engine at 202,500mi (Donkey85)
You put it in using a vacum on ur car. like the brake booster Vacum. if you poor this stuff in, it could have the potential to Hydro lock ur car. It sucks it in a little a time. and does its thing.
Old Sep 28, 2004 | 10:17 PM
erikiksaz1's Avatar
Default Re: just SEAFOAMED my engine at 202,500mi (pogiTSI)
Kinda creeped out to try this idea. The disadvantages outweigh the advantages by quite a bit, or rather...the price of a new headgasket
Old Sep 28, 2004 | 11:01 PM
kwichang's Avatar
Default Re: just SEAFOAMED my engine at 202,500mi (erikiksaz1)
Seafoamed my rex at 220,000 just before my smog (re)test to help bring down the NOx. Slowly put in 1/2 can in through the brake booster.
Noticed a big difference in throttle response immediately. It seems like it was temporary though...feeling like a tired A6 again 5000 miles later.
Didn't know about the headgasket issues before I did it or I might have been afraid to use it.
Just add very slowly and admire all the smoke while you're passing the time Do a search theres an excellent photo write up how to do it
Side Note: my radiator fan never ever comes on, but it did while seafoaming - must have gotten pretty hot in there...
Old Sep 29, 2004 | 12:35 AM
kurinto's Avatar
Default Re: just SEAFOAMED my engine at 202,500mi (kwichang)
I used a similar product by valvoline. My neighbor used to work for them and had an extra demo pack of the stuff on him. It made a pretty noticable difference in throttle response and doesn't seem like it was only temporary. It made a LOT of smoke come out and it smelled pretty bad. Of course I was happy with it cause it was free...but it seems a lot like seafoam and I hear its only a few bucks a bottle.
Old Sep 29, 2004 | 04:35 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: just SEAFOAMED my engine at 202,500mi (kurinto)
seafoam only is sold at napa
Old Sep 29, 2004 | 07:10 AM
4drEF's Avatar
Keyboard Humorist
I've done the same with injector cleaner to clear out everything after failing smog results. After sucking a bottle of injector cleaner in through a vacuum line I was able to fix the areas it was failing for smog!
Old Sep 29, 2004 | 07:56 AM
99sonicbluegsr's Avatar
Default Re: just SEAFOAMED my engine at 202,500mi (MugenHonda)
advance auto parts and batteries sells it also
Old Sep 29, 2004 | 08:51 PM
Donkey85's Avatar
Default Re: just SEAFOAMED my engine at 202,500mi (99sonicbluegsr)
to sum it up you can pretty much get it at any auto parts store
Old Sep 29, 2004 | 09:39 PM
RCautoworks's Avatar
I will copy and paste my response from the eg forum
I keep seeing all these sea foam post and I thought I would post a little info, sea foam is not always great, I have seen many people use it and have horror stories about it. Blown head gaskets, lack or oil pressure. One of the main things sea foam does is break up all the sludge and it falls down to the oil pan and that could be a big mess. Customers usually ask me about it and I tell them water works wonders. You take a spray bottle ( the ones that mist ) and you hold the throttle open a little with the engine running and you spray a little every now and then. What your doing is steam cleaning the inside of your engine and everything is being burned off rather then falling to your oil pan.
Old Sep 29, 2004 | 10:35 PM
GSRCRXsi's Avatar
no its not, ive seen it at advance auto parts.
Old Sep 29, 2004 | 10:44 PM
RAB's Avatar
RAB
Default Re: just SEAFOAMED my engine at 202,500mi (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">I will copy and paste my response from the eg forum
Interesting. I'm currenty piecing together a D16a6, clean motor, but the IM ports are sludged up, are you saying that if I spray mist water into the TB that sludge in the IM will be burned off?
Old Sep 29, 2004 | 10:46 PM
Default Re: just SEAFOAMED my engine at 202,500mi (RAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAB &raquo;</TD></TR><TR><TD CLASS="quote">Interesting. I'm currenty piecing together a D16a6, clean motor, but the IM ports are sludged up, are you saying that if I spray mist water into the TB that sludge in the IM will be burned off? </TD></TR></TABLE>
Yep, think about it and it should become clearer. Your spraying mist into the engine, once it makes it to the head and the engine its gonna burn off but it will also burn everything else off. Next time it rains or is wet out, try to notice if your engine is running any better.
Old Sep 29, 2004 | 11:02 PM
Reelizmpro's Avatar
aka water injection...hehe, I'd be careful doing it though. Water is not volatile and you have more potential to hydrolock. If you do that make sure it's from a small vac hose or use a fine mist. Another great product is AutoRX, a lot of people use it religiously but it's quite expensive ($24 a bottle) and it's like a 4 step process and you change your oil and filter in between each step. Anyway, at $5.99 for Seafoam I decided to try it today and I didn't see much smoke come out...just a little but I did notice that response picked up. I used a spray bottle to spray it into 2 different locations on the intake manifold. I also poured some into the crankcase. I'm going to run about 1500 miles and do an oil change. BTW, the sludge created by the Seafoam in crankcase will be filtered by the oil filter which is why they recommend you change your oil and filter after 1500 miles or so in anticipation of the stuff building up in your filter.
Old Sep 29, 2004 | 11:21 PM
Default Re: just SEAFOAMED my engine at 202,500mi (Reelizmpro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro &raquo;</TD></TR><TR><TD CLASS="quote">aka water injection...hehe, I'd be careful doing it though. Water is not volatile and you have more potential to hydrolock. </TD></TR></TABLE>
If you don't know what your doing you do, its pretty simple though. Take a hair spray bottle, set it to miss, get the rpms around 3,000 and spray every now and then. The only way your gonna lock your engine up is from dumping the hole spray bottle in the throttle body.
Old Sep 30, 2004 | 05:01 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">What your doing is steam cleaning the inside of your engine and everything is being <U>burned off rather then falling to your oil pan. </U>
so how does anything get from the combustion chamber to the oil pan again?
Old Sep 30, 2004 | 05:49 AM
virginia_dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">seafoam only is sold at napa</TD></TR></TABLE>
Advance auto sells it.
