Just got my jdm itr lsd installed, how to test if it's working?
Old Sep 28, 2004 | 02:57 PM
initialvtec's Avatar
Default Just got my jdm itr lsd installed, how to test if it's working?
I jacked up the front and put it in gear and spun one tire and the other spun the opposite direction. I've heard people saying that it should spin the same direction if you have lsd..??? I took it to a empty parking lot and burned out, it layed two clean 10ft black strips. (i know thats not a very accurate to test for lsd). I also hear i could take out the axles and look through? are there any other ways to test to see if its working poperely? I've already searched, and most of the answers are opposite of each other. Help!
Old Sep 28, 2004 | 03:00 PM
Haleiwa-Brando's Avatar
Default Re: Just got my jdm itr lsd installed, how to test if it's working? (initialvtec)
You want to test and see if it's working? Get in your car, drive across the Kelso bridge to Oregon...when your dropping down the back side of the bridge, you know that on ramp to the high way that goes shooting up the hill toward the coast? Take that bitch at about 60 and if you end up in the guard rail...it's not working.
Old Sep 28, 2004 | 03:03 PM
KOALA YUMMIES's Avatar
Default Re: Just got my jdm itr lsd installed, how to test if it's working? (Haleiwa-Brando)
Yeah, thats great advice...
It depends if the car is in gear or not when you're spinning the wheels. Ive never personally taken notice (on my past two cars that had LSDs) of which way they spin though.
The drive-shaft method I have seen (before my motor was swapped in my old hatch) you look through the driveshaft hole and if you can see the other driveshaft without any obstructions (itd look like a 1cm wide bar going through if there were) then its for sure an LSD.
Old Sep 28, 2004 | 03:15 PM
98itr0448's Avatar
drop the clutch at 5k and see if you put down two tire marks or just one ....
Old Sep 28, 2004 | 03:17 PM
Default Re: Just got my jdm itr lsd installed, how to test if it's working? (98Itr-0448)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98Itr-0448 &raquo;</TD></TR><TR><TD CLASS="quote">drop the clutch at 5k and see if you put down two tire marks or just one .... </TD></TR></TABLE>
did that! layed two marks down. Don't really wanan do that shaft thing, i'm lazy lol.. and don't know what i'm doing.
Old Sep 28, 2004 | 03:21 PM
OMG... :walks away shaking head:
Old Sep 28, 2004 | 03:27 PM
FatBoy4door2's Avatar
Default Re: Just got my jdm itr lsd installed, how to test if it's working? (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, thats great advice...
The drive-shaft method I have seen (before my motor was swapped in my old hatch) you look through the driveshaft hole and if you can see the other driveshaft without any obstructions (itd look like a 1cm wide bar going through if there were) then its for sure an LSD.</TD></TR></TABLE>
you are just telling him how to check and see if his tranny has it, he is trying to tell if it WORKS, apparently it does work due to your description, even try peeling out in dirt and see if your peel out with 1 or two tires but it sounds like it works right now
Old Sep 28, 2004 | 03:31 PM
Default Re: Just got my jdm itr lsd installed, how to test if it's working? (FatBoy4door2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatBoy4door2 &raquo;</TD></TR><TR><TD CLASS="quote">
you are just telling him how to check and see if his tranny has it, he is trying to tell if it WORKS, </TD></TR></TABLE>
No ****! He also asked:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by initialvtec &raquo;</TD></TR><TR><TD CLASS="quote"> I also hear i could take out the axles and look through? are there any other ways to test to see if its working poperely?</TD></TR></TABLE>
Try reading n00b, the main reason this board has **** is because people dont read. I dont post for the hell of it.
Old Sep 28, 2004 | 03:35 PM
Koala....you don't seem to be in a very good mood right now.
Old Sep 28, 2004 | 03:39 PM
The n00b attacked me whe he didnt even read the whole first post. He's been here a whole 4 days.
Old Sep 28, 2004 | 03:41 PM
&lt;-- sorry for starting a war
rzz's Avatar
rzz
the easiest way to test lsd
dont be so eman to me
stop all the yelling
Old Sep 28, 2004 | 03:46 PM
Hahaha you guys are funny. Its not a war, itll just be a massacre .
stop all the yelling </TD></TR></TABLE>
You're my new favorite n00b.
Old Sep 28, 2004 | 03:50 PM
PY 01-0972's Avatar
if you gas it out of a drive way heading left or right you can feel the front claw its way out in front of you. its a very different feel without LSD
Old Sep 28, 2004 | 04:33 PM
markpaco's Avatar
Your LSD works. The helical LSD will rotate will opposite directions.
Old Sep 28, 2004 | 07:37 PM
six_speed's Avatar
in gears one will spin one way the other will spin the other way. In nuetral however, both wheels are indenpendent of each other.
Old Sep 28, 2004 | 07:46 PM
Accord94DX's Avatar
Default Re: (Humping_dragon)
shift into 1st at 80mph, if your tires dont lose traction you have LSD
Old Sep 28, 2004 | 08:44 PM
Default Re: (Accord94DX)
hah.. In neutral the other tire doesnt move at all when i rotate one side.
Old Sep 28, 2004 | 10:14 PM
R you serious's Avatar
jeff---&gt; who is having a better night tonight than yummies
Old Sep 28, 2004 | 10:20 PM
Default Re: Just got my jdm itr lsd installed, how to test if it's working? (R you serious)
Oh what the heck is that!??!! D0000D! Whered you get that!? I have to go back to Chicago to have fun like that!
Old Sep 28, 2004 | 10:26 PM
Accord94DX's Avatar
oishisoooooooooooo
Old Sep 28, 2004 | 10:30 PM
Default Re: Just got my jdm itr lsd installed, how to test if it's working? (Accord94DX)
lotte koala no marchi,....
choketo kookie no oishi harmoni!!!!
Old Sep 28, 2004 | 10:39 PM
Accord94DX's Avatar
ahahhhahahhahahhahahahah hthats ******* awesome
tabetai kedo ima muri, mn de sore ga zenzen nashi y0
Old Sep 29, 2004 | 05:04 AM
.RJ's Avatar
.RJ
wtf is going on here?
*runs away*
