Will 90-91 CRX Si Rims clear Integra Front & Rear Brakes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylefakesi-r »</TD></TR><TR><TD CLASS="quote">yes. all honda 14 inch wheels will clear teh caliper without needing to be notched.</TD></TR></TABLE>
Not HX Rims...
<---Speaking from experience.
Not HX Rims...
Most likely not. I know for a fact that 90-91 wheels wont clear Integra-sized brakes, at least not the fronts.
actually those rims WILL clear the front. they are on my buddies car right now with full integra suspension/brakes. they are jsut a tight squeeze.
After some searching i have found some conflicting responses. I will find out on saturday when i install. I have other rims to use if necessary but the tires are better on the crx si's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoGoHF »</TD></TR><TR><TD CLASS="quote">I second that. I have LS all around with SI rims, close fit, but fits good.</TD></TR></TABLE>
88-89 crx si wheels??
100% positive 90-91 crx si rims will hit the caliper if you have integra front brakes. The rim will bolt on fine, but once you spin it you will notice the blade hits the caliper slightly. The rears will be fine though. Not sure about 88-89's though
well after working on the integra brakes this weekend. I can confirm 100% that the 88-89 Crx Si wheels will NOT fit over the integra brakes.... luckily i had a set of 15's that did...
Also since installing the brakes the amount of steering effort required has increased, as well as road feedback. Has anyone else expereinced this??
hrmm that fittment problems is weird. we had a 89 crx si and it got smashed, so we took those oem rims and put them on my buddies ef with full integra susp/brakes.
maybe those rims were already slimmed down... but thats wierd.
sry if I was wrong then, cuz it honestly works, its a DD too so w/e.
PhatBoy5015
Oct 18, 2005 11:09 PM
menappi
Mar 1, 2005 04:02 AM
