Occasional stall going into neutral
Old Sep 28, 2004 | 02:42 PM
Yield's Avatar
Default Occasional stall going into neutral
another random stall thread...
Right now I'm getting a very occasional stall. It probably happens about once a week. It only happens when I'm coming to a stop and put in the clutch. The revs automatically drop and they just drop too far and it can't catch itself. Once I start it up again it's fine again for another week or so!! Idle is smooth, as is acceleration. No CELs or known problems with the car.
I did a valve adjustment a couple months back and that lowered my idle a tad but not to the point were it threatened to stall. I recently had a leak in a rad hose but I think that was after the stalling started so I don't think any air is in the system, plus the smooth idle makes me think I'm fine.
Should I just try adjusting the idle screw or do you think something is failing here?
BTW, it's a 93 SI
Old Sep 28, 2004 | 07:02 PM
optikal_blitz's Avatar
Default Re: Occasional stall going into neutral (Yield)
Try raising your idle back up.
Old Sep 28, 2004 | 07:16 PM
sleepy_vtec's Avatar
Default Re: Occasional stall going into neutral (NatakuBlitz)
yeah, adjust the idle on the trottle body. Mine was doing that until i adjusted it!
b20bFourDoorCivicLX
Apr 16, 2013 08:34 PM
2low93
Feb 17, 2012 04:13 AM
joelmatt89
15
Nov 4, 2009 05:27 PM
spock_rocker
Oct 17, 2007 08:11 AM
tylerdurden
Apr 11, 2003 05:53 PM
