What is a EGR system?
Old Dec 12, 2001 | 01:42 PM
Spade's Avatar
Default What is a EGR system?
I want to swap my HX intake man. for an EX and I am told that I will loose my EGR system, what the heck is that?
Okay, Exhaust gas return system....why would a HX have it and a EX wouldn't?
[Modified by Spade, 2:48 PM 12/12/2001]
Old Dec 12, 2001 | 01:49 PM
HXMan's Avatar
Default Re: What is a EGR system? (Spade)
It is the exhuast gas recirculation system. It routes exhuast gas back into the intake.....it reacts with some other bad chemical in the cylinder, to lower that type of emission.
I think it must have something to do with the Hx lean burn operation. Burning fuel as lean as an Hx does, creats more NOx I belive....so recirculating exhuast gas helps deal with that problem somehow.
Old Dec 12, 2001 | 01:54 PM
Spade's Avatar
Default Re: What is a EGR system? (HXMan)
how much of a difference did you notice with the EX intake and trottle body?
Old Dec 12, 2001 | 02:06 PM
CivicV10@18000rpm's Avatar
The EGR system lowers the peak combustion temperatures which reduces NOx's. EGR's are used mainly at part throttle. The system is off at idle(which would cause roughness if on) and full throttle(which would reduce full power if it was on).
Old Dec 12, 2001 | 02:09 PM
Spade's Avatar
Default Re: What is a EGR system? (CivicV10@18000rpm)
are egr's on the other D engines?
Old Dec 12, 2001 | 02:28 PM
Hmmm...don't know.
Old Dec 12, 2001 | 02:30 PM
thefordmccord's Avatar
i'm pretty sure the HX is the only one with an EGR system
Old Dec 12, 2001 | 02:42 PM
Spade's Avatar
Default Re: What is a EGR system? (thefordmccord)
here is the final question, would it benefit perfomance wise to remove the EGR system?
Old Dec 12, 2001 | 02:49 PM
I would assume it would help...especially at part throttle.
Old Dec 12, 2001 | 06:19 PM
HXMan's Avatar
Probably would be a good thing to remove....but you won't be able to pass smog thats for sure.
Oh, I never did the manifold swap.
Old Dec 13, 2001 | 06:18 AM
Spade's Avatar
**** new topic in Hybrid. https://honda-tech.com/zerothread?id=100883
[Modified by Spade, 7:36 AM 12/13/2001]
GSR-C5
Aug 19, 2010 04:57 AM
imzjustplayin
Apr 21, 2008 10:19 AM
whoobeedoobee
Sep 7, 2003 06:13 PM
Greyout
Jun 24, 2003 08:07 AM
Drews Bitch
Dec 25, 2002 01:02 PM
