Crx B16A swap HELP
I have my B16A coming out my EK going into a 91 CRX SI would my axles work for the Crx. also regarding mounts do I have to use mounts along with shift linkage for a hydro tranny or if I but the hydro mount kit do I only use the kit and not the shift linkage. its also running a P30 ECU I already bought the obd-OBD1 harness what else would I need to make this work.
any help would be great
Thanks
Thanks
you need a hasport ef- hydro mount kit, hasport adjustable shift linkage, i dont think you can use the ek axles, i dont think they will fit in the crx hubs, in addition to that harness you need a obd1 distro, and injectors (wich im sure you already have) you still need to run your wires for vtec, vtec oil pressure switch, knock, and your going to have to make some changes for the 4 wire o2 sensors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wid326 »</TD></TR><TR><TD CLASS="quote">Great that was great help thank you very much
You dont need to change injectors. you can re-use the 1991 crx si injectors.
if u do get obd-1 injectors you will have to remove and by pass the resistor box. Not the most difficult thing to do, but just a little more work involved (and money).
</TD></TR></TABLE>You dont need to change injectors. you can re-use the 1991 crx si injectors.
As for the axels, I just replaced mine with a 90-93 integra axels
if you are taking out the B16 from you EK and in to your 90 CRX Si of course it will work they are both EK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 EF »</TD></TR><TR><TD CLASS="quote"> if you are taking out the B16 from you EK and in to your 90 CRX Si of course it will work they are both EK
What are you talking about?
96-00 hatch = ek
88-91 crx/civic= ef
The axles will work on the tranny side, but im not sure they will work in the hubs themself.
</TD></TR></TABLE>What are you talking about?
96-00 hatch = ek
88-91 crx/civic= ef
well, im not entirely positive if it will work or not, you might try fitting them in the hub before you swap just to check and make sure, if you were using a cable tranny, you would use 90-91 integra axles, i would assume that those would work in a hydro tranny also, but im not 100% positive.
BigPlansNoMoney
Mar 2, 2005 05:32 AM
Dainbramage
Apr 25, 2004 08:06 AM
