car hesitates to start up in the morning
Old Sep 28, 2004 | 10:00 AM
AlphaKennyWun's Avatar
Default car hesitates to start up in the morning
Car sometimes doesnt start in the morning.
It cranks and cranks and cranks and nothing happens.
I wait, keep cranking and nothing.
Wait longer, keep cranking and the car starts up.
Car runs fine once it starts, car runs hard and keeps running all day long.
Only happens in the morning after its been sitting
When I crank it it shows 45psi fuel pressure on my gauge on fuel rail
Its been about 3 months with same spark plugs
Its been about 10 months with same rotor/cap/wires
Its been about 1.5 years with same fuel filter
I often run the car to empty.
Should I replace all the maintenance stuff again then replace distributor?
what else can I do?
Old Sep 28, 2004 | 12:29 PM
Default Re: car hesitates to start up in the morning (Turbo Chris)
bump
Old Sep 28, 2004 | 01:00 PM
Dropped90Integra's Avatar
i have the same problem with my 92 LS right now, its only in the mornings or been sitting that is does it, I hope someone out there knows because I would like to know why its doing it too.
Old Sep 28, 2004 | 01:02 PM
RuskeR's Avatar
Check your battery and Altenator
Old Sep 28, 2004 | 01:04 PM
yeegsr's Avatar
battery, starter want some money or what...crank crank sound like ur starter is dying trying to get you to get a new starter
Old Sep 28, 2004 | 01:06 PM
Well not sure with the other guy but my car will crank all day long, it'll start than shut off real quick, start again than shut off real quick, probably a few more times than I have to hold the gas to the floor and start it to get it running than it'll stay started and start the rest of the day perfectly fine
Old Sep 28, 2004 | 02:02 PM
Default Re: car hesitates to start up in the morning (IntegraB18LS)
Starter is very strong and there is plenty of juice in the battery...
Ive gone through dead batteries, alternators and starters already
this is an entirely new problem.
Im leaning toward either a bad: cap, rotor, plugs, filter or lastly the dizzy.
Its only when I first try to start in the morning, once it starts it runs all day.
Modified by Turbo Chris at 6:12 PM 9/28/2004
Old Sep 28, 2004 | 06:27 PM
no problems this morning
up
Modified by Turbo Chris at 7:15 AM 9/29/2004
Old Sep 29, 2004 | 05:19 AM
JimBlake's Avatar
Battery & starter sound OK since it cranks strong.
Wake up & try while it's still real dark out. Have someone crank while you watch for arcing on the cap & wires. Your cap & wires aren't very old (mine are older...) but you never really know until you check.
After ruling that out, you can suspect ignitor or coil. Maybe a flaky ignition switch, but I don't understand why that would only happen in the morning. Electrical stuff under the hood would be more affected by cold & dew.
DSBP1
33
Jun 29, 2009 04:04 PM
debogsr
Apr 18, 2006 01:14 AM
PurEvl
Dec 11, 2005 05:55 PM
deftones0817
Jul 14, 2005 08:17 AM
Audio28
Jul 3, 2003 05:33 PM
