WHite smoke coming out when starting cold
Old Sep 28, 2004 | 09:49 AM
davejj40's Avatar
Default WHite smoke coming out when starting cold
it smells like gas not coolant, and it aint blue white, so it cant be oil.....You guys think i might be running rich.....plugs seem to back that up.....The white smoke...btw its not thick, stops after the car is warm....not gutted cats either...
Old Sep 28, 2004 | 11:12 AM
TunerN00b's Avatar
Default Re: WHite smoke coming out when starting cold (davejj40)
Its been my experience that white smoke is coolant/water. Fuel too rich usually looks black. If you have too much condensation in the exhaust after parking it, that might do it too I suppose.
Check to make sure you're not losing coolant. If you aren't, and it only happen immediately after a cold start, I wouldn't worry too much, but you might want to ask a mechanic too.
Old Sep 28, 2004 | 01:03 PM
B18C-VTI_R's Avatar
Default Re: WHite smoke coming out when starting cold (TunerN00b)
dam are you stupid or something because cold engine then suddenly heats up make white smoke. like you breathing in cold weather make white smoke come out of your mouth, and because in cold weather it tends to rev higher and richer until engine warmed then it dissapears
Old Sep 28, 2004 | 10:18 PM
nyteflyte2003's Avatar
im having that problem but with my 90 LS it stays white then after a while idling the CEL comes on and it kills itself. help me out plz.
Old Sep 29, 2004 | 11:56 AM
B18C-VTI_R's Avatar
Default Re: WHite smoke coming out when starting cold (nyteflyte2003)
adjust your throttle cable or its your timing
Old Sep 29, 2004 | 03:33 PM
Default Re: WHite smoke coming out when starting cold (B18C-VTI_R)
ok can you maybe point me in the right direction to fix both?
Old Sep 30, 2004 | 12:36 PM
B18C-VTI_R's Avatar
pop open the hood and you should do this when the engine is idling correctly. find adjustable cable. it should be the one that rev the car. undo the bolt abit, just enough to adjust then tighten it, that should fix it
dailyekhatch
Aug 15, 2011 06:45 AM
shytdoode
20
Feb 27, 2010 01:57 PM
Bruce Banner
Feb 16, 2007 05:59 PM
CRX_Control
Nov 10, 2004 09:29 PM
T_SweepeR_BB6
Dec 6, 2003 08:39 PM
