boosting only 6-8 on stock engine w/ stock inj...probs?
Old Sep 28, 2004 | 03:23 AM
al3e's Avatar
Default boosting only 6-8 on stock engine w/ stock inj...probs?
...i plan on going Z6T, with a custom kit, 14b cx mani, a 12:1 FMU, 2.5 piping with just a side mount *mounted as a fmic* .... i have looked on other boards.. some people say i should run 450cc inj... or someother stuff..i think i would be fine with my stock ones... correct...?
...maybe i didnt search long enough.. someone always finds something... but im sorry. i looked long and hard.. many different boards... yes turbod15, hmt, d series, here and chb.com.
Old Sep 29, 2004 | 09:15 AM
al3e's Avatar
Default Re: boosting only 6-8 on stock engine w/ stock inj...probs? (al3e)
Old Sep 29, 2004 | 10:34 AM
djwest24's Avatar
with the FMU, stick with stock.
Old Oct 1, 2004 | 02:07 AM
al3e's Avatar
Default Re: boosting only 6-8 on stock engine w/ stock inj...probs? (quicksilver17981)
yeah.. peeps are crazy
Old Oct 1, 2004 | 03:44 AM
beerbongskickass's Avatar
You can run stock injectors with an FMU, but your fuel pressure will be really high and your injectors will probably be maxed out. It's probably a better idea to upgrade to some 450cc injectors and get good fuel management (uberdata, hondata, aem ems, etc...).
Old Oct 1, 2004 | 05:18 AM
tgreaves's Avatar
Default Re: boosting only 6-8 on stock engine w/ stock inj...probs? (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">You can run stock injectors with an FMU, but your fuel pressure will be really high and your injectors will probably be maxed out. It's probably a better idea to upgrade to some 450cc injectors and get good fuel management (uberdata, hondata, aem ems, etc...).</TD></TR></TABLE>
Agreed, If your have the money this without a doubt is your best option..
Old Oct 1, 2004 | 08:55 AM
Broken Gearbox's Avatar
If you got the money get the DSM 450cc's with an Apexi VAFC and run the hack but the FMU with stock injectors can hold up to 6psi.
Old Oct 1, 2004 | 09:12 AM
Default Re: (2.2L)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2L &raquo;</TD></TR><TR><TD CLASS="quote">If you got the money get the DSM 450cc's with an Apexi VAFC and run the hack but the FMU with stock injectors can hold up to 6psi. </TD></TR></TABLE>
I would rather run the afc setup than the FMU (if those were the only choices), but you have to remember to do something about the ignition retard since the afc advances your timing quite a bit. A MSD btm would be a good idea also if your going with the afc.
Old Oct 1, 2004 | 09:28 AM
yea i would run the hack to...it just depends if he wants to spend that much. also the MSD btm would be a good thing to get too, so you can adjust your timing.
Old Oct 1, 2004 | 09:52 AM
tgreaves's Avatar
Default Re: (2.2L)
The btm isnt going to help much with the afc since its still advanced way to far..
Go here for a thread that I made about a way to fix the afc ignition problem..
https://honda-tech.com/zerothread?id=1009014
And who is the girl in your avatar?
Old Oct 1, 2004 | 09:55 AM
Default Re: (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">And who is the girl in your avatar?</TD></TR></TABLE>
Yes, I too would like to have sex with your avatar.
Old Oct 1, 2004 | 09:57 AM
tgreaves's Avatar
Default Re: (beerbongskickass)
Yes, I too would like to have sex with your avatar. </TD></TR></TABLE>
I agree, Is the avatar available tommorow night?
Old Oct 8, 2004 | 11:12 AM
al3e's Avatar
so 450 injs with some sort of idling helper, and the 12:1 fmu... with vafc?
Old Oct 8, 2004 | 11:14 AM
No FMU, just the afc and 450's... You also need to do something about your ignition too.
Old Oct 8, 2004 | 01:23 PM
I agree, Is the avatar available tommorow night? </TD></TR></TABLE>
lol...shes available everynight. for me only.
Old Oct 8, 2004 | 01:54 PM
tgreaves's Avatar
Default Re: (2.2L)
lol...shes available everynight. for me only. </TD></TR></TABLE>
Ahh, what fun is that for us.. Ill trade you a blown d15b7 for one night with her..
.....Wait, how old is she?
Old Oct 8, 2004 | 03:03 PM
SOHC_MShue's Avatar
i think the fmu will work for 6-8psi, but it really isn't gonna be that great of a setup. Instead of doing the hack I would just chip your ecu and go with uberdata...its probably cheaper in the end anyways. The stuff to chip the ecu is only like $15 for the components to be soldered, $6 for a chip, and $80 for a rom burner. Thats less then an afc costs.
Old Oct 8, 2004 | 06:57 PM
djwest24's Avatar
Default Re: boosting only 6-8 on stock engine w/ stock inj...probs? (SOHC_MShue)
yea, i wouldnt bother getting an afc. not worth the money. so chip ur ecu and run a rom editor, for half the money. or stick with the FMU.
Old Oct 8, 2004 | 07:02 PM
raene's Avatar
At 6psi on the hack you'd be running mid-map on the stock ECU, meaning ~30 degrees advance under boost. You really don't want to touch the hack except at 10psi.
Chip the ECU + join the dark side
Old Oct 9, 2004 | 05:47 AM
HitEm'Up's Avatar
U can run the stock injectors--but really consider an upgrade
Old Oct 9, 2004 | 09:28 AM
al3e's Avatar
Default Re: boosting only 6-8 on stock engine w/ stock inj...probs? (98turbohatch)
:/ well i guess till i can find someone near here...who can tune my car for cheaper than some guys i have asked... ill prolly go uberdata and get rid of the fmu...
but untill then, its the 12:1 fmu with stock injectors only at 6-psi (hopefully with a vafc) if i can afford it soon
thanks for the help buddies
darkirony
Oct 14, 2004 07:48 AM
Cezilla
Mar 28, 2004 08:21 AM
mtber
Jul 21, 2003 08:06 AM
GOLDBERG
Apr 13, 2003 05:16 PM
1bar
Jan 22, 2003 07:44 AM
