Another fully built h23a is done.... thanks A\V Engineering!
Old Sep 28, 2004 | 12:35 AM
Nikoli's Avatar
Default the motor is done!....dyno inside
as some of yall know i hydrolocked about 4 months ago and have been down since.
Well its finally done, thanks to A\V Engineering aka anthony(precisionh23a). He built the motor from the bottom up, had the block darton sleeved, installed the motor, installed the turbo kit and made a custom 3" exhaust and its running like a champ. this past weekend anthony, mase, jeff and i went down to miami and boca to go dyno and this what we came out with
344hp/287tq @ 13psi thanks to mase it is tuned to the T up top while anthony did a bang up job tuning it for driveability.
h23a1
darton iron sleeves
je pistons 9:1
gude race head- pnp, 5angl.
gude pnp and port matched IM
aem pullies
aem fpr
aem fuel rail
walbro 255fp
rc 720cc injectors
jg cam gears
t3/to4e .57 trim turbonetics turbo
turbonetics delta wastegate
rev hard manifold
rev hard IC
2"- 2.25" ic piping
vortech bov
2.5" down pipe
full 3" exhaust
apexi muffler
3" flex pipe
msd 6al
msd coil
Modified by Deckedlude at 10:14 PM 1/23/2005
Old Sep 28, 2004 | 12:47 AM
@ries's Avatar
Default Re: the motor is done!....dyno inside (Deckedlude)
Congrats man! She must pull like a bat outta hell.
Old Sep 28, 2004 | 12:57 AM
Nikoli's Avatar
Default Re: the motor is done!....dyno inside (@ries)
all i have to do now is get a radiator that can handle it
the stock replacement radiator that i have is acutally smaller than the original so i have to getg another before i really get on it. plus my msd box went on my home so have to get another one those also. once they are replaced i'll let you know
Old Sep 28, 2004 | 01:11 AM
Luchini's Avatar
Prelude powa
How much did it cost to build up your bottom end?
Old Sep 28, 2004 | 02:54 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: the motor is done!....dyno inside (Luchini)
Awesome, that thing is a beast!
Pic is down.
Old Sep 28, 2004 | 04:28 AM
preludeez's Avatar
Default Re: the motor is done!....dyno inside (Sticky Tires)
well done and congrats man!
Old Sep 28, 2004 | 05:43 AM
OTT's Avatar
OTT
Another wicked Prelude start tearing up the streets turbo style, Congrats man
Old Sep 28, 2004 | 06:16 AM
PrecisionH23a's Avatar
Bottom end build ups run roughly 2,500. But nick had a lot more than just a bottom end build-up.
Nick's car was a real pain in the ***, but in the long run it turned out quite nicely. I'm very satisfied with the results as I feel he is as well. I'll try to add some pictures up a little later as well if Nick does not mind sharing them.
Well... back to work on another customers car... this one should hit around the same power since 300 is all the guy wants out of the motor.
Old Sep 28, 2004 | 06:54 AM
thehondaguru's Avatar
Default Re: the motor is done!....dyno inside (PrecisionH23a)
what cams are you running? OEM?
Old Sep 28, 2004 | 06:57 AM
Default Re: the motor is done!....dyno inside (95 lude)
yep... oem.
I have a set of gude turbo cams he was going to buy off of me but he was too broke, lol.
Old Sep 28, 2004 | 07:03 AM
Kal's Avatar
Kal
why not a tial wg?
Old Sep 28, 2004 | 07:13 AM
Default Re: the motor is done!....dyno inside (Kal)
Because we thought we got one with the kit... it was the only wastegate we could find in time. Plus, the ****** boosts 16psi with a 7psi spring, so that's money saved on a MBC, hehe.
The motor could have put down some more power in my opinion, but this car is a daily driver and another 30-40whp is really not going to make that much of a difference. Plus, it is only running a 57 trim turbo.
Old Sep 28, 2004 | 09:25 AM
SKDRCR's Avatar
Very nice numbers Nick
Good job on the build up Anthony
Old Sep 28, 2004 | 12:06 PM
Nikoli's Avatar
Default Re: the motor is done!....dyno inside (SKDRCR)
thanks
Old Sep 28, 2004 | 12:11 PM
Here is some eye candy:
Setting the ring-end gap.
Shortblock assembled and darton sleeved.
Go home!
Welcome home...
I'll have some more snaps of the engine bay later tonight.
Old Sep 28, 2004 | 12:34 PM
eLUDEnu
Guest
Posts: n/a
NICE!!!!!
Old Sep 28, 2004 | 12:48 PM
FawkJoo's Avatar
Default Re: the motor is done!....dyno inside (eLUDEnu)
sweet setup man, should haul ***
Old Sep 28, 2004 | 01:02 PM
ralpheezy's Avatar
Default Re: the motor is done!....dyno inside (FawkJoo)
damn man awesome setup. how much did all that cost you?
Old Sep 28, 2004 | 02:04 PM
DLB1994's Avatar
Default Re: the motor is done!....dyno inside (ralpheyizzle)
not bad but i did make 334whp and 317wtq at 12psi with a drag manifold and a t3/t04e 57trim on a deltagate, 756cc injectors
but i was 10.2:1 comp with a all stock head & stock cams and intake manifold
nice power band
is this on pump gas
Old Sep 28, 2004 | 02:15 PM
Default Re: the motor is done!....dyno inside (DLB1994)
Yes, this is on pump gas and timing was very conservative as this is a daily driver. I actually hit those same numbers on a 50 trim and 14psi of boost, does that mean I can get a cookie? That's neither here or there though. Nicks boost gauge is also a pile of **** which read all over the place so we interpreted values through hondata. I believe it was just a hair shy of 1 bar if that makes you feel any better.
As I stated, more power could have been easily made but due to a hurricane coming we had to pack up shop and get the hell out of miami, lol.
Old Sep 28, 2004 | 02:30 PM
@ries's Avatar
Wow Anthony... I had know idea you had such pretty hands.
Nice job on the build. Thats some clean work
Old Sep 28, 2004 | 02:39 PM
Dancing is Forbidden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">not bad but i did make 334whp and 317wtq at 12psi with a drag manifold and a t3/t04e 57trim on a deltagate, 756cc injectors
</TD></TR></TABLE>GET THE MAN A COOKIE!!
Old Sep 28, 2004 | 02:50 PM
DLB1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Yes, this is on pump gas and timing was very conservative as this is a daily driver. I actually hit those same numbers on a 50 trim and 14psi of boost, does that mean I can get a cookie? That's neither here or there though. Nicks boost gauge is also a pile of **** which read all over the place so we interpreted values through hondata. I believe it was just a hair shy of 1 bar if that makes you feel any better.
As I stated, more power could have been easily made but due to a hurricane coming we had to pack up shop and get the hell out of miami, lol.</TD></TR></TABLE>
ok smart *** , all i was saying i was thinking it should have made more power at 16psi for the setup, i was thinking you made more with less boost and less mods
and yes a chocolate chip cookie would be nice
but what do i know
Old Sep 28, 2004 | 02:54 PM
How was I being a smart ***? I answered your questions.
Old Sep 28, 2004 | 03:08 PM
but what do i know </TD></TR></TABLE>That Balance Shafts make your engine smoke.
