Better times at night or in the day?
Old Sep 27, 2004 | 08:45 PM
Waachback's Avatar
Default Better times at night or in the day?
What are the ups and downs of racing in the night and in the day? Also which will net you a better time?
Old Sep 27, 2004 | 08:54 PM
Donkey85's Avatar
Default Re: Better times at night or in the day? (Waachback)
night time, you will have better numbers, the air is cooler thus the car runs better
Old Sep 27, 2004 | 09:15 PM
91civicEX's Avatar
Default Re: Better times at night or in the day? (Donkey85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">night time, you will have better numbers, the air is cooler thus the car runs better </TD></TR></TABLE>
but some tracks require you to have lights on so it will make the alternator work. i assume this is at a track cuz ur tlakin about numbers right?
Old Sep 27, 2004 | 09:25 PM
Donkey85's Avatar
Default Re: Better times at night or in the day? (91civicLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">
but some tracks require you to have lights on so it will make the alternator work. i assume this is at a track cuz ur tlakin about numbers right?</TD></TR></TABLE>
whats your point??? the alternator is working all the time anyway, what does that have to do with anything
Old Sep 27, 2004 | 09:28 PM
ProjectDarkBlack's Avatar
pavement is cooler at night, dense air has more resistance to flow (if that will even make a difference) if you have a black hood the sun may make the egine bat a few degrees warmer the pavement may expand stretching the actual distance haha i dunno
Old Sep 27, 2004 | 09:53 PM
crex23's Avatar
Default Re: Better times at night or in the day? (ProjectDarkBlack)
Nighttime
But on another note, the weather now (fall weather) is still great weather to race in during the day.
Old Sep 27, 2004 | 10:34 PM
Waachback's Avatar
Thats what I have been telling my friend, but he still says that racing in the day is better.
Anyone else have input?
Old Sep 27, 2004 | 10:39 PM
NONVTECSI's Avatar
Doesn't matter, just depends on the temperature. Yes, during the day its hotter and during the night its cooler, but everywhere it is different. But if I had to give an answer night time.
Old Sep 28, 2004 | 11:17 AM
Waachback's Avatar
Anyone else? Night or Day?
Old Sep 28, 2004 | 06:48 PM
EF_generation's Avatar
Default Re: (Waachback)
racing in the day?! more popo checks than a stoned pothead in a stolo!!
or imagine the massive downshifting when a grandma off her meds gets in yo way!!!!
Old Sep 28, 2004 | 07:05 PM
sinfultrends's Avatar
Default Re: (el_payaso)
daytime is better cuz you can see those kidz crossing the street..
Old Sep 28, 2004 | 07:13 PM
Default Re: (sinfultrends)
what kind of dumb-*** kid is gonna be walking to school at two in the morning
Old Sep 28, 2004 | 07:35 PM
MoonSha's Avatar
FI motors would have an advantage at night to the denser cold air, I think the traction/cold would balance out for NA cars?
Old Sep 28, 2004 | 08:35 PM
The ZC's Avatar
Default Re: Better times at night or in the day? (MoonSha)
During the day isnt the track warmer?
Warm Track = More Traction
Old Sep 28, 2004 | 09:21 PM
Joebroni's Avatar
Yes, but the hotter the air, and generally the more humid the air. You always want colder air, that is what every racer tries to obtain, and colder temperatures occur when the sun goes down.
Assuming you are running N/A and dont have to worry about heatsoak, after a few passes at a track the tires should be warm regardless of how cold the track is.
My car will literally break loose in second shift during these seasons, whereas I can barely get a chirp during the summer months.
Old Sep 28, 2004 | 09:23 PM
Joebroni's Avatar
And generally, you only have to run with your corners on, not the entire headlight. Varies track to track, but that's how it is out here (midwest). Headlights on would take a sizeable load, but corners wont.
Old Sep 28, 2004 | 10:52 PM
B16 ED9's Avatar
Default Re: (Joebroni)
Night time
Old Sep 29, 2004 | 04:41 AM
StorminMatt's Avatar
But lights only consume about 55watt apiece when the low beams are on. Given the inefficiencies of your electrical system, you are probably only drawing about 150watts from your alternator. This is about .2HP, which is negligible compared to the increased power from cooler air.
Dave-ROR
Jul 16, 2008 02:27 PM
JDM_COUPE94
Mar 6, 2007 04:25 AM
TangJianYu
Mar 11, 2004 08:51 AM
ZUL8R
16
Dec 29, 2003 04:30 PM
bOOsTiNSoHcVtEc
Oct 17, 2003 09:57 PM
