does my 89 dx have a mass airlfow sensor or not?
Old Sep 27, 2004 | 07:25 PM
89hbcivicguy's Avatar
Default does my 89 dx have a mass airlfow sensor or not?
i have an 89 dx and its not gettin enough air to the intake could this be bacause of a mass airflow sensor? does ti have one?
Old Sep 27, 2004 | 07:42 PM
green91's Avatar
NO, it does NOT have a MAF sensor. your not "getting enough air" because the DPFI sucks.. (no pun intended)
Old Sep 27, 2004 | 09:11 PM
Donkey85's Avatar
Default Re: (green91)
i concur
Old Sep 28, 2004 | 02:41 AM
StorminMatt's Avatar
Default Re: (Donkey85)
As far as I know, Honda does not use mass airflow sensors.
Old Sep 28, 2004 | 03:08 PM
Default Re: (mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">03-04 accord k24 has MAF.......</TD></TR></TABLE>
YUCK!
I hope this is not the beginning of a trend.
Old Sep 28, 2004 | 03:27 PM
rioninja's Avatar
MAP=manifold absolute pressure=sucks for boost... </TD></TR></TABLE>
Im curious as to why you say that MAP sucks for boost?
While its true that it cant measure air density, a map sensor coupled with
an intake temp sensor and atmospheric pressure sensor make it pretty damn
acurate. More accurate than is needed to run the car consistently.
MAP + IAT + atmospheric sensor = great for determining air density.
Old Sep 29, 2004 | 02:57 PM
Default Re: (rioninja)
I don't understand why anyone would say that speed density sucks for boost (or other applications) Yes, it is known to not compensate for slightly increased airflow as well as MAF systems. But you can always reprogram the ECU. And let's face it. If you are running a MAF system, it becomes quite easily to max out the system and require reprogramming and a larger MAF as well. Also consider that even for MAF cars, stand alone systems typically convert to speed density. This should tell you which system is REALLY better.
Old Sep 29, 2004 | 03:12 PM
RCautoworks's Avatar
Default Re: (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">YUCK!
I hope this is not the beginning of a trend.</TD></TR></TABLE>
It already is, take a look at the new suspension on Honda's, its like looking at a domestic setup.
EFstyle
11
Jul 28, 2008 06:45 PM
slowB20ej8
35
Jan 3, 2008 03:10 PM
Hondacivic91dx
Jul 24, 2007 07:45 AM
b18cEK
12
Mar 29, 2006 10:18 AM
Layziebtnh055
Apr 14, 2004 07:58 AM
