70 mm bbk throttle body making noise
Old Sep 27, 2004 | 07:24 PM
civicaleg's Avatar
Default 70 mm bbk throttle body making noise
I have a bbk throttle body on a skunk 2 intake. This thing makes a really loud whisle. Is this normal? any ideas?
Old Sep 27, 2004 | 07:30 PM
builthatch's Avatar
MiG-21 superfan
Default Re: 70 mm bbk throttle body making noise (civicaleg)
is it the new style without an idle screw that uses the throttle stop for idle?
Old Sep 27, 2004 | 09:49 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicaleg &raquo;</TD></TR><TR><TD CLASS="quote">I have a bbk throttle body on a skunk 2 intake. This thing makes a really loud whisle. Is this normal? any ideas? </TD></TR></TABLE>
oh jesus are you running that 70mm....that's huge...how much power do you output....
well im running stock TB and it does some whisttle sound sometime only when i quick rev the engine at a normal temp...at cold temp it doesn't ...it doesn't do that alot though....but when i hear that sound it came from the intake...not at the TB i think
but 70mm is huge for watever your engine unless you got big power at the wheel
Old Mar 26, 2005 | 07:55 PM
Shizznaz's Avatar
Default Re: 70 mm bbk throttle body making noise (yeegsr)
so you saying 70 mm is too big? I dont get it
Old Mar 26, 2005 | 07:58 PM
2k.civic.si's Avatar
Default Re: 70 mm bbk throttle body making noise (Shizznaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shizznaz &raquo;</TD></TR><TR><TD CLASS="quote">so you saying 70 mm is too big? I dont get it</TD></TR></TABLE>
nope...just means you may lag a bit in the low end
Old Mar 26, 2005 | 08:33 PM
da9project's Avatar
the hole on a sk2 im is 64mm so you have 6mm of restriction against the tb, and what gasket are you using,this is y u wistle that tb is too big btw, imo 62mm tb with a sk2 that way the air can't revert,
Old Mar 27, 2005 | 04:26 AM
typerman's Avatar
Default Re: (da9project)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da9project &raquo;</TD></TR><TR><TD CLASS="quote">the hole on a sk2 im is 64mm so you have 6mm of restriction against the tb, and what gasket are you using,this is y u wistle that tb is too big btw, imo 62mm tb with a sk2 that way the air can't revert, </TD></TR></TABLE>
Old Mar 27, 2005 | 03:47 PM
Shizznaz's Avatar
Default Re: (typerman)
I bought a 70 mm BBK throttle body as well as the 70 mm bbk throttle body, this going to cause any problems? They arnt installed yet.. since.. im still waiting on the throttle body ( been a month now! wtf! ) I also bought the BBK throttle body gasket set. So it all should fit nice and perfect. Will I need my engine to be tuned because of the new throttle body? just making sure everything will work out in the end
rsf-g
Oct 2, 2007 05:42 PM
memorybox
Sep 19, 2006 11:07 AM
kevin7kevin7
Jul 11, 2006 12:22 PM
ultra efro
Feb 22, 2004 05:53 AM
crxtreme27
Aug 31, 2002 11:49 AM
