who has the highest mileage on AFTERMARKET sleeves ? Post here
who has the highest mileage of aftermarket sleeves with no sinking issues?
company:
Sleeve type:
Mileage:
block series:
and if you want : motor setup
turbo set up
horsepower rating.
company:
Sleeve type:
Mileage:
block series:
turbo set up
horsepower rating.
company: Earl assembled/Benson slv'd
sleeve type: open deck (all Benson does...)
mileage since build: about 4000 miles and about 3 months
block: b18c5 (9:1 cp's and 83mm bore/pauters/stock b18c5 head)
daily driven @ 310 whp on mustang dyno (@15psi on smaller t3/t4)
most as of yet = 331whp on 19psi
company: sfp assembled/darton sleeved
sleeve type: closed deck/wet sleeve
mileage since build: 16000 miles/ 1 year
block: b18c1 (9:1 JEs and 81mm bore/crower/cometic hg)
stock tb/stock im/stock head/hondata 2b (sfp tuned)
daily driven @ 315 whp (@14psi SC 61 turbo)
after a couple new upgrades:
Im looking for 350 hp daily @14 psi 93 octane/425hp @20ish psi on race gas
Modified by Turbo Chris at 11:40 PM 9/27/2004
company: Golden Eagle Mfg
Sleeve type: Godzilla sleeves
Mileage: 19000 miles
block series: B18C1
Gone through a couple of headgaskets, but cannot pin-point what was the issue. It was more likely from the head, but I switched setup and I am no longer running the block anymore.
company: Rocket Motorsports
Sleeve type: custom dartons with a GE block gaurd
Mileage: 13000 miles
block series: B18C1
engine has been daily driven for the last 5 to 6 months and has seen 40+ trips down the 1320..engine makes 550+ whp on high boost and 307 on 7 psi and pump gas..still runs like a charm but the valve guilds need to be replaced.
only problem I had was when I tried to run nitrous on high boost and had it set to damn rich it lifted the head pulling the HS threads with it..but thats all been fixed and its back to running great!!
block series: B18C1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markaria »</TD></TR><TR><TD CLASS="quote">company: Earl assembled/Benson slv'd
...</TD></TR></TABLE>
they do closed deck, im having one done...what he meant in that post was that they dont close open decks.
company: AEBS
Sleeve type: T-Sleeves
Mileage: 24000
block series: B18C1
motor setup: 84MM, 9.5:1, Ported head, ITR Cams, ITR Trans
turbo set up: InlinePro T4 Mani, PTE 750 HP IC, PT67 .68 A/R P-trim
horsepower rating: 433 WHP, pump gas
Started off at stock bore 9:1 comp with an SC61, blew that up after about 5 thousand miles. Bored it to 84MM with some custom 9.5:1 JE's, put the PT67 combo on there, and I drive it LOTS.
Mileage: 24000
block series: B18C1
Sleeve type: Semi-closed
Mileage:21000 miles
block series: B18C1 81.5mm
horsepower rating: 350-420whp tuned by Autowerks Motorsport
14psi Daily on 93 Octane gas
Mileage:21000 miles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Chris »</TD></TR><TR><TD CLASS="quote">company: sfp assembled/darton sleeved
Modified by Turbo Chris at 11:40 PM 9/27/2004</TD></TR></TABLE>
this may sound ignorant, but I thought Cubans werent allowed to have new cars.
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">
this may sound ignorant, but I thought Cubans werent allowed to have new cars.</TD></TR></TABLE>
WHAT!??!
WHAT!??!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">
WHAT!??!
with the whole communism thing.. I know that there are lots of old 1950's-60's chevys, and oldsmobiles and pontiacs, etc. Im just asking because I didnt know the average person could get newer cars there
WHAT!??!
</TD></TR></TABLE>with the whole communism thing.. I know that there are lots of old 1950's-60's chevys, and oldsmobiles and pontiacs, etc. Im just asking because I didnt know the average person could get newer cars there
Darton Block sleeved by stoid racing
Eagle Rods
Endyn pistons
81.0mm
ls vtec
18k miles and still going strong
Eagle Rods
Endyn pistons
81.0mm
ls vtec
Maybe its not the case of how long sleeves last but more of how long someones setup will last. Im sure all the people that run sleeves run high horsepower and other things cause the sleeves to get ruined. (thrown rod, Melt a piston) What i wonder is you sleeved a block and ran it like a normal car what would happen. (this would be kind of pointless for sleeves.) but then you could tell if issues developed over time.
hope this came out right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">this may sound ignorant, but I thought Cubans werent allowed to have new cars. </TD></TR></TABLE>
Yes you are ignorant and that has nothing to do with this post. But since you brought it up - there alot of older American cars there because there has been an embargo on Cuba since the 60's therefor they cannot get any American goods. But that doesn't mean they cant get new cars from Japan or Europe.
That concludes our history class for today, there will be a pop quiz.
Oh and:
company: Benson
Sleeve type: Open Deck 84mm
Mileage: 2,000 miles
block series: B18C1 with LS crank
company: Benson
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">
Yes you are ignorant and that has nothing to do with this post. </TD></TR></TABLE>
That sounds like a personal attack there. I know very little about Cuba, and I tried to be polite with the comment so suck a dick.
