Who has a turbo ZC???
Hey my brother has a ZC rex that he now wants to go turbo in. I'm trying to find out what he's going to need to accomplish this. Or what setup you are currently running with your ZC. Money is definitely going to be a factor so he's trying to go the cheapest yet most reliable way. Thanks in advance guys.
i found this site a while ago,hope this helps,cool little site,too bad this guy doesnt update it and i dont think he posts on HT
http://hometown.aol.com/elevenseczc/...geprofile.html
I have a turbo ZC. Im running a Greddy kit at 5.5 pounds with no problems. Im using colder spark plugs, retard the timing, and used a FPR. She didnt blow up on me yet
use the 92-95 civic kit.... the piping will work if you use it creatively... a couple small grinds to the bottom corners of the manifold allow it to clear the zc block and a nice little dent to the crossmember allow the downpipe to clear....as long as you keep low boost, you'll be able to get away w/ a boost dependent fpr. otherwise, you'll have to replace the rods b/c they're not too safe after 200hp. might as well throw in some low comp pistons while you're doing the rods....
the 92-95 sohc vtec greddy turbo kit fits. the manifold and all bolts up but you have to modify the intercooler piping for fitting in your car.
.cingham
Feb 17, 2004 09:43 PM
REDBARON
Dec 23, 2001 12:46 AM
